11-24-2019, 11:56 PM
2020 27' Globetrotter
2019 Interstate Lounge Ext
Jackson Hole - Tetons
, Wyoming
Second Battery Tray 2018 ASI
Hi y’all
What’s the consensus for the best place to acquire a second battery tray to accommodate (add) two additional batteries?
11-25-2019, 01:31 AM
2007 22' International CCD
Corona
Originally Posted by ScottP
Hi y’all
Depends on the battery type. Flooded lead-acid lives outside somewhere for venting hydrogen fumes overboard. Sealed AGM and Lithium types can be installed inside somewhere that makes electrical and weight placement sense. No simple answers here without many more details from you!
11-25-2019, 06:58 AM
2013 Interstate Coach
Raymond
, Iowa
There is a thread about problems if using the normal Airstream mounts for placing underneath. Something about poor choice of how/where to rivet. So look up that thread if you are thinking about underneath. Much as the rest of the AI weighs (10,000 #), I can't think that it is too important where you place the extra 150# of two batteries. Biggest issue I would think is to mount them securely.
11-25-2019, 03:48 PM
, Wyoming
Thanks all
Outside: Sealed batteries
Would like to mount the same as current tray from factory
Will be reinforcing AS rivet mount
No room in cabin
11-27-2019, 04:25 AM
Prof. of Pending Projects
2018 Tommy Bahama Interstate
Orlando
To answer your question. Only place to get the trays from is Airstream... so get them from local dealer. That is what I did.
11-27-2019, 04:29 AM
Orlando
2 - Part # 454982 - Battery tray, AGM CL24, End mount - there is no need for anything else. The tray includes the metal strap for the battery...calling tomorrow to confirm order with dealer
12 - Part # 325128 - 1/4" stainless steel rivets
2 - Part # GPL-24T - Life Line AGM Grp-24 Battery
11-27-2019, 04:33 AM
Orlando
What they look like...
11-27-2019, 07:12 PM
, Wyoming
Oh you High Achiever 🥳
You should consider opening a Patreon account  )
Thank you very much,
