Old 10-05-2023, 03:53 PM   #1
2017 Interstate Grand Tour Ext
Ashburn , Virginia
Replacing LP Regulator on Interstate
Hi, all. Is there a good way to get to the propane regulator on the AI? Mine is a 2017 24GT. I crawled under my van and was a little discouraged to see that it's situated in a metal box behind the hose spool for the gray/black water dump (see the attached pictures). Maybe it's less daunting than it appears. Otherwise, I'm starting to wonder if I should schedule an appointment with the nearest Airstream dealer. Thanks!
Name:	regulator looking aft.jpg
ID:	437526   Click image for larger version
Name:	regulator looking forward.jpg
vaboater is offline   Reply With Quote
Old 10-14-2023, 09:18 PM   #2
2013 Interstate Coach
Niceville , Florida
Drop the metal box by unhooking the hose from the Macerator and then removing 3 screws. I just replaced the valve because it was bad. While I was in there, I replaced the regulator.
sc_jay is offline   Reply With Quote
Old 03-25-2025, 06:07 PM   #3
Parker , Colorado
Hello, I have same Airstream Interstate just 2016 and the LP regulator is leaking. Was you able to replace it and where did you find a new one. I called Airstream dealer and they are 6 weeks waiting time. Sergei
Sergei is offline   Reply With Quote
Old 03-26-2025, 07:50 AM   #4
Ashburn , Virginia
Hi, Sergei. My problem actually turned out to not be the regulator, so I didn't replace it. The fuel level gauge had broken. It registered as partially full when it was actually empty, so I had actually run out of propane without realizing it.
Old 03-26-2025, 10:10 AM   #5
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
Ask the Airstream people quietly if they can recommend another outfit. That's what I did here in the ABQ area and found the place that does very good service without the months of waiting that happens at Airstream.
Lynn
ACI Big Red Number 21043
Old 03-26-2025, 01:27 PM   #6
2015 Interstate Grand Tour
Libertyville , Illinois
I just replaced mine a month ago: JR Products 07-30375 Excess Flow POL Regulator, SILVER, available on Amazon for $52
It's a little larger than the original on my 2015 GT but it fit after removing the plastic guard that covered the old one. In my opinion the location has enough protection from the elements and the guard wasn't doing much anyway
Works great, no more propane smell
Schmitte is offline   Reply With Quote
Old 03-26-2025, 09:34 PM   #7
Parker , Colorado
Thank you! I was able to remove old regulator, it took less than hour. Found a new one on EBay for $35. Should receive it on Saturday.
Old 03-26-2025, 09:36 PM   #8
Parker , Colorado
Airstream dealership offered a new one for $150 and 6 weeks waiting, plus $300 for labor.
Old 03-30-2025, 02:32 PM   #9
Parker , Colorado
Hello everyone, finished project today. $35 for a brand new LP regulator, $4 for LP tape and about hour and half to remove old and install new. Used Rino plastic ramps under driver side rear wheels to raise RV enough to be comfortable under. Didn't remove or disconnect anything except old regulator. No propane leak anymore.
Replacing LP regulator advice AKbound LP Gas, Piping, Tanks & Regulators 2 11-19-2020 07:06 PM
Replacing main LPG line from regulator Safari64 LP Gas, Piping, Tanks & Regulators 4 09-26-2018 05:41 AM
Replacing Hose Between Regulator & Bottle Cannonball LP Gas, Piping, Tanks & Regulators 6 12-08-2014 11:14 PM
Hose from tank to regulator needs replacing Doug C LP Gas, Piping, Tanks & Regulators 1 06-14-2013 11:35 PM
Replacing water pressure regulator Tin Hut Plumbing - Systems & Fixtures 11 11-26-2012 07:00 PM
