Old 05-25-2020, 07:26 AM   #1
2012 Interstate Coach
Wayne , Nebraska
Question Replacement gearbox
Have a 2011 Interstate with a sliding door crank-out window gear box stripped.
Have not found a way to repair short of replacing the whole window!
There has got to be a better Way!
Ron
Wayne Fire11 is offline   Reply With Quote
Old 05-28-2020, 10:57 AM   #2
Wayne , Nebraska
Exclamation
Was hoping someone from Airstream would see this and offer some help.
Ron
Old 05-28-2020, 03:37 PM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Ron
You might need to contact an Airstream dealer for help. You likely have CR Laurence windows. They only sell through distributors.
http://www.crlaurence.com/crlapps/sh...h=30587::21889
Parts are available from distributors. I bought a vent window glass panel from DK Hardware for half what the Airstream dealer wanted.
https://www.dkhardware.com/cr-laurence_ZM1P1.html
Airstream does not sell parts directly to retail customers, you must go through a dealer. The biggest challenge is getting a replacement part number so you know what to order.
Good luck!
- - Mike
Old 05-28-2020, 04:31 PM   #4
Wayne , Nebraska
Good luck!
Yes I have CRL windows. Have been in contact with RV One in Des Moines IA. They tell me the numbers supplied by both CRL and Airstream don't match.
Will try your suggestion to try DK hardware.
Ron
Old 05-29-2020, 06:00 PM   #5
Fulton , Maryland
Ron
I did get the part number via email from CRL before I placed the order from DK. But they should be able to identify the the part you need. It might help if you get the part number for the whole window assembly from the CRL web site.
- - Mike
Old 05-29-2020, 08:17 PM   #6
Wayne , Nebraska
Ok will try that
Old 06-26-2020, 07:09 PM   #7
Wayne , Nebraska
Gear box
A follow-up on my gar box issue.
Bit the bullet and ordered a whole new window, got it installed today,
now able to get the rig on the road!
Was not able to get any real help from either Airstream or C R Laurence, so went with Window Discounters and did it my self!
To bad I had to get a whole window for a gear box part!
Chev 400 Auto Gearbox Ted OShann Mechanics Corner - Engines, Transmission & More... 7 01-24-2017 12:49 AM
Gearbox Mjgman Sprinter and B-van Forum 5 08-12-2016 05:13 AM
Steering coupler - between gearbox & column bkahler Mechanics Corner - Engines, Transmission & More... 10 10-16-2012 08:30 AM
need steering gearbox for 1977 argosy 24 dillmann Member Introductions 1 05-22-2008 11:24 AM
Window lifting arms/gearbox Walker's Wanderer Windows & Screens 2 03-25-2004 07:46 AM
