Old 08-18-2018, 03:26 PM   #41
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by TayaraTravel View Post
I don't use the inverter part of the Magnum at all. It is shut off. (We don't use TV or other A/C consumers when on battery or solar power.) We installed an interior LPG switch, and always cut off the LPG unless actually cooking or heating water. We have the Victron MPPT solar controller. I do the "long push" on the Fusion.
I haven't tested the batteries, so it's possible we either got a bad original set from Airstream factory, or our initial weeks-long dealer service visit allowed them to deplete through neglect.
My estimate of State of Charge is coming from the voltage reported by the Magnum and confirmed by the Victron bluetooth app. I'm assuming that 12.0 or so volts means I'm down to 50% SOC. I realize this is not resting voltage, so maybe I'm underestimating SOC.
How much current does the Nova Kool frige/freezer draw? I have separate units (not sure about the model number). It's a 2017 van.
TAYARA - I think the unit in you GT is a Nova Kool RFU6200. If so it draws 5.2A when the compressor is running. That is based on this spec sheet.
http://novakool.com/support/document...cLTCurrent.pdf
If you van sat for weeks on a dealer lot with no charging with stock setup the original batteries might be damaged. Also you Fusion may still be drawing power as many have reported on this forum. That would draw down the batteries too.
The only way to know what's happening on the load side is to have a shunt based current meter that measures all current flow into and out of the house batteries. I think they can be added to the Victron solar controller. I have one on my BlueSky controller and it is very helpful for monitoring battery health and status.
- - Mike
Old 08-19-2018, 07:45 AM   #42
2017 Interstate Grand Tour Ext
Houston , Texas
Thanks. At some point in the future, when the batteries age, we will upgrade our system. There are no AI electrical specialists here in Houston, so we'll need to schedule a trip around it. Things are working now, and we can go one night off grid with no problem. More would be nice, but we can live with and enjoy what we have.
Leigh & Bettie
Houston TX
2017 Interstate GT
BMW R1200GS
TayaraTravel is offline   Reply With Quote
Old 07-22-2020, 02:35 PM   #43
CANON CITY , Colorado
It’s on the name plate on the inside left on both units
Blazeman1 is offline   Reply With Quote
Old 07-25-2020, 01:00 PM   #44
On name plates on left inside of both
ABS drainage system - 2005 Classic RoadToad 2001 - 2005 Classic 16 01-29-2009 01:36 PM
Urgent vintage grey water drainage question! 1959newbie Waste Systems, Tanks & Totes 6 04-21-2007 09:58 PM
Water Tank Drainage popeyedoyle1 Fresh Water Systems 8 03-07-2006 04:50 PM
16' ccd Bambi drainage system question. gbrentsmith Waste Systems, Tanks & Totes 12 10-17-2005 09:08 PM
