Old 06-11-2019, 01:18 PM   #41
2013 Interstate Coach
Raymond , Iowa
I noticed a slight propane smell for a while, and checked it out with some leak detector spray. Found a slight leak (bubbling) where the bleed valve screws into the fitting that is welded to the back wall of the compartment. Tightened the fitting every so slightly and the leak stopped. Plan to buy a new bleed valve and install it next time the LPG tank is empty.
Titus is offline   Reply With Quote
Refilling propane tank sciggy87 Base Camp 5 04-24-2019 02:37 PM
LP tank removal for refilling DeltaRon 2016 - Current Classic (all lengths) 11 07-16-2018 07:15 AM
Northeast Refilling potable water Mifair Boondocking 18 08-22-2012 03:00 PM
New Valves & Refilling 30# Aluminum Tanks nairnchyz LP Gas, Piping, Tanks & Regulators 21 04-07-2009 07:20 AM
LP Tanks (Refilling) silversled LP Gas, Piping, Tanks & Regulators 6 12-29-2006 08:51 PM
