03-15-2016, 07:12 PM
2014 Interstate Ext. Coach
Boca Raton
Rear view mirror and camera
What I'd like to do is move rear view camera screen off rear view mirror to able to to view rear of coach.
Anyone done this or have ideas to a suction cup or bracket to remove screen from rearview mirror???
03-15-2016, 07:26 PM
Boca Raton
03-15-2016, 07:27 PM
Airstream Obsessed
2006 30' Classic
1989 29' Excella
Sandy
, Utah
I plan on doing the same thing on my Ford F150. When I do it I'll let you know how it goes.
03-15-2016, 07:32 PM
Muskogee
, Oklahoma
If it's the Pyle unit, it just has spring loaded clamps. You just push them apart and it comes off. But you will have to unhook the cable by removing the overhead compartment and finding where it connects to the camera. It is removed by gently pulling down on the curbside side (the overhead compartment is held in with spring loaded clamps on that side, and with flat legs on the other. Pull it down, and then to the curbside (right as you face it) and it will fall away. Then follow the wire from the monitor and unplug it.
It's easy to do. You can, if you want, re-route the cable and display the rear view camera image in the Kenwood deck.
2011 Interstate WD/Lounge (since sold).
2020 Leisure Van WonderRTB
03-15-2016, 07:55 PM
Boca Raton
Not looking to remove it
Just install next to rearview mirror
03-15-2016, 07:56 PM
Boca Raton
Originally Posted by Teamaron
That's not my mirror
Just an example
03-15-2016, 10:39 PM
Muskogee
, Oklahoma
It is held on to the mirror with two spring loaded clamps. You can pull it off and put it anywhere you were wish, but you will have to figure out some way to mount it.
03-15-2016, 11:44 PM
2015 Interstate Ext. Coach
Lake Mary
Yes, there is the original Sprinter mirror underneath, and aftermarket one simply hangs on it. Just pull it out by hand.
03-16-2016, 10:46 AM
2013 30' Classic
Greenwood
, Mississippi
Or have the rear view camera image show up on your Kenwood double DIN-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
03-16-2016, 01:34 PM
Lake Mary
m.hony, do you know how to wire it? If yes, can you share it with us?
03-16-2016, 03:57 PM
Muskogee
, Oklahoma
You have to get an RCA jack video extension cable, run it from the RCA out from the camera located overhead in the compartment, and run it to the back of the Kenwood deck's RCA video input.
I actually have a RCS jack dual splitter, and display both images, one on the camera and the other on the Kenwood deck because the picture on the mirror/monitor is so poor.
03-16-2016, 05:05 PM
2013 30' Classic
Greenwood
, Mississippi
What he said.
Take it to a car stereo store.
Around here labor might be $65.
I have 2 cameras using my Alpine double DIN as a monitor with an a/b toggle switch.
Up is the truck's backup camera.
Down is the camera on the back of my trailer.
TAC #MS-10
Airforums #70955
03-16-2016, 06:43 PM
Lake Mary
Thanks you Gentelmen, and I would prefer to do it my self, not because of the money but in order to safe parts or some clips, etc, that they will most likely brake. The most challenging is to remove the Kenwood unit...
03-16-2016, 06:47 PM
San Diego
I am with you, just haven't gotten around to it.
Not sure if there is room but was thinking about fabricating a bracket and mount it over the mirror.
03-16-2016, 08:03 PM
2011 Interstate Coach
Overland Park
, Kansas
To answer your original question w/o rewiring anything, I got a visor clip on mirror and when I need to see what's going on in the rear, just flip the sunvisor down and viola, there it is.
Glass half full or half empty to an engineer is the glass is twice as big as it needs to be.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
03-16-2016, 08:39 PM
Lake Mary
Can you please picture it, Marc?
03-16-2016, 08:43 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
I installed a wireless rear view camera on the truck, and one on the trailer, both on the same frequency. Each has it's own on/off switch. When not hooked up, I see what is behind the truck. When hooked up, I turn off the truck camera, turn on the trailer camera and see what is behind the trailer.
03-16-2016, 11:36 PM
2016 27' International
Livingston
Hello - what wireless rear view camera do you have on your trailer? I've heard about communication issues with wireless cameras being too far from the receiver and having lots of aluminum in between.. but I'd really like to get one I can one that works... Thanks! :-)
Vicki
03-17-2016, 03:22 AM
2013 30' Classic
Greenwood
, Mississippi
Similar to my setup, but the truck camera is wired and the trailer camera is wireless on my rig.
TAC #MS-10
Airforums #70955
03-17-2016, 04:07 PM
Overland Park
, Kansas
On my side . . .
On wife's side . . .
