Old 07-20-2020, 12:16 PM   #1
Traverse City , Michigan
Rear sofa removal
So how do you remove the sofa bottom seat cushion on a 2016 GT Ext? I see a nut on each side towards the rear to remove to lift it off, are there more?
Does the seat need to be reclined to lift the bottom cushion? Assuming that is the case and there is no power to the sofa, any other way to remove it? Asking for a friend 😁
Heckler56 is offline   Reply With Quote
Old 07-20-2020, 02:11 PM   #2
2013 Interstate Coach
Waterloo , Iowa
If yours is like my 2013 there are two nuts (1/2") on the seat back that you remove from the rear. There are two bolts with nuts (7/16") on the front of the seat bottom. You need to recline couch a bit to get the seat bottom to slide forward for access to the phillips screw head..
Titus is online now   Reply With Quote
Old 07-20-2020, 04:46 PM   #3
Any thoughts how to make it slightly recline without power? Maybe I can get a angle Phillips screwdriver in there.
Old 07-20-2020, 05:13 PM   #4
Indianola , Iowa
You’re going to have to keep the battery connected till you get it reclined to where you need it before you remove the sofa back and then do what you need with the sofa again before you disconnect the battery. The sofa may be one of those things that stay live even with the battery switch by the slider turned off.
nateallen80 is offline   Reply With Quote
Old 07-20-2020, 06:27 PM   #5
Thank you both. I was able to get an angled Phillips head in there.
Since the electrical is torn down, putting power to it was not an option. Will reconnect once system is up and running.
sofa removal 2005 CCD eggman Interior Restoration Forum 0 05-25-2020 11:54 AM
Removal of front sofa 30'Classic SO tadpoletim Cabinets, Counter Tops & Furnishings 3 08-10-2016 01:03 PM
Sofa drawer removal-'97 31' Excella 1000 bwoodtx General Repair Forum 2 07-17-2016 09:29 AM
Sofa cover for jack knife sofa k9jackie Sprinter and B-van Forum 0 05-28-2015 05:30 PM
Sofa removal done! Cost to recover? Splitrock General Interior Topics 2 08-02-2010 12:59 PM
