Old 09-04-2019, 01:07 PM   #1
Forest City , North Carolina
Rear door light conduit part number
The flexible rubber conduit that goes from the rear wall to the rear door has come loose from the wall. The ears are broke off the plastic holder in the wall. I have not been able to find a replacement, probably because I have no idea what Mercedes would have called it.
Tom Hamrick
2016 Interstate EXT GT Twin
tomhamrick is offline   Reply With Quote
Old 09-04-2019, 01:15 PM   #2
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Ocala , Florida
Alex had to replace it... one sec... let me see if I can quickly find it... he shared part number
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 09-04-2019, 01:17 PM   #3
wachuko's Avatar
Ocala , Florida
This??
Link to Alex's thread:
http://www.airforums.com/forums/f240...ml#post2254520
Safe travels!
Wachuko
WBCCI #26769
Old 09-04-2019, 01:18 PM   #4
That's it!! Thanks for the fast reply!
Old 09-04-2019, 02:59 PM   #5
2018 Interstate Lounge Ext
LV , Nevada
Tom Hamrick
TOMHAMRICK - You did not specify driver side (L) or pass. side (R). They are NOT IDENTICAL & not interchangeable because the bend of the mold is specific to how the door opens.. The part# that WACHUKO posted from my Add 2nd Rear LowLux Cam at bumper, Monitored by Fusion thread/mod is for the driver's side
Alex AVI is offline   Reply With Quote
Old 09-05-2019, 05:44 AM   #6
Thanks Alex, mine is for passenger.
Old 09-05-2019, 09:02 AM   #7
LV , Nevada
TOMHAMRICK - I suspected that would be the broken one from normal use since that door gets opened lots more than the driver side. Mine was broken from a self-inflicted removal.
Passenger side = MB part number: A0009971051.
This is the whole assembly, flex protective hose with 2 plastic inserts that press-fit into wall & door. You can not order just the plastic inserts, don't even try, I already went through the whole process. I did not buy the passenger side, so I can not confirm part# to actual part in front of me, so double check with your dealer that part# has not changed before you order.
Old 09-06-2019, 05:57 AM   #8
Thanks again!!!
Conduit /Raceway LaurieRS Electrical - Systems, Generators, Batteries & Solar 5 04-07-2019 07:27 AM
Part Number for 1997 Airstream Land Yacht Amber Clearance Light Johnsito Lights - Interior & Exterior 1 02-12-2015 12:15 PM
Seal Part Number I am repacking wheel bearings and seals have no part number. Ditter Wheels, Hubs & Bearings 9 05-05-2013 02:17 PM
Running wiring, conduit? rodsterinfl Electrical - Systems, Generators, Batteries & Solar 4 04-03-2012 05:26 AM
What kind of conduit is this? TitusLivy Electrical - Systems, Generators, Batteries & Solar 2 02-18-2008 12:47 PM
