Old 05-11-2021, 03:31 PM   #1
ScottP's Avatar
2019 27' Globetrotter
2018 Interstate Lounge Ext
Jackson , Wyoming
Quick and Dirty ... Macerator Question
OK - my very first time with a macerator pump experience. Yucky
Mulitplex Wiring Setup - 2018 Coach
Macerator Motor - No Power:
We hardly use the restroom on our vans, certainly never the shower for some reason ... so minimal use, for sure no kids toys, rope, or fem napkins etc... for sure
Fuse?
20 Amp Macerator Fuse on a 2018 unit is where please?
I checked the circuit breakers aft driver's side jump seat ...is there another fuse location I'm not aware of?
I get confused (easily) and recall the fuses being under the drivers seat, accessible from an open drivers door on prior vans (2017?)
Thanks all - embarrassed to post ...
8 AS Interstate's owned: All Black Lounges
2014, 2014.5, 2015, 2016, 2017 (4x4), 2018 (4x4), 2019 (4x4+air suspension), current is a new 2018 (4x4+air suspension)
2019 AS 27' Globetrotter & 2019 F350 Plat Diesel
Rye, NH and Jackson, WY
ScottP is offline   Reply With Quote
Old 05-11-2021, 04:42 PM   #2
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Macerator fuse is under the RS jump seat. There is a list of fuses next to the physical fuse on my 2018.
I replaced the provided 20 amp fuse with a 20 amp slow-blow fuse. The slow-blow fuse will handle the surge from a slow-starting macerator without blowing. I have never blown one since on two successive coaches.
Ours is used at every coach use. My private toilet is one of the reasons I have a van. I don't understand folks that do not use it.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 05-11-2021, 07:17 PM   #3
Hawk-ination's Avatar
2014 Interstate Ext. Coach
Cedar Rapids , Iowa
Don’t forget the screw on the side. Turn with a screwdriver when the macerator is off to make sure the impeller is not stuck. There’s a cover you need to take off the end of the pump if I remember correctly.
Hawk-ination is offline   Reply With Quote
Old 05-11-2021, 08:04 PM   #4
Rig Rat's Avatar
2015 Interstate Ext. Coach
Columbus , Ohio
I have searched unsuccessfully for slow-blow fuses. Do you have a source or link for them that you’d be willing to share with us?
Adventure before Dementia!
Rig Rat is offline   Reply With Quote
Old 05-11-2021, 08:09 PM   #5
Contributing Member
Pahaska's Avatar
Sorry. Bought them years ago. Took a lot of trouble finding them.
Old 05-12-2021, 04:43 AM   #6
2017 Interstate Lounge Ext
Mount Jackson , VA
Our macerator kept blowing the fuse. We used the screw to move the macerator blades to have it blow again. My husband then pulled the macerator out and discovered hair wrapped around the blade was the problem. We are the third owners and had not used the shower yet. After cleaning out the hair all was well. We now have a strainer in the floor drain of the bathroom to try and catch hair and debris.
We use our bathroom all the time. Even showered in it recently when the RV park we stopped at overnight did not have open showers. Worked fine. Most impressed with the hot water heater.
MountainLife is offline   Reply With Quote
Old 05-12-2021, 07:48 AM   #7
ScottP's Avatar
Jackson , Wyoming
We use it, just doesn’t get many cycles with one or two people traveling occasionally.
Thanks all for the skinny on the fuse, and manual flathead turn on the pump checking the impeller
Old 05-12-2021, 10:10 AM   #8
Contributing Member
Pahaska's Avatar
If the motor will not run or you do not have a fuse, you can turn the impeller (clockwise) with a flat screwdriver bit chucked in a battery-operated drill.
John W. Irwin
WBCCI #9632
Old 05-12-2021, 12:29 PM   #9
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
My Class A does not have a built-in macerator, I have a Sewer Solution that is water-powered, hook it up to the tank output.
If your fuses are the "standard" cartridge fuses then the replacement is a 20 amp "microwave" fuse. They have a white ceramic middle instead of clear glass and you should be able to get them at any decent hardware store or, of course, Amazon. Get at least 2.
Cliff & Andrea,
two snowshoe cats, have not been camping yet
TerraYacht is offline   Reply With Quote
Old 05-12-2021, 12:29 PM   #10
TerraYacht's Avatar
Cliff & Andrea,
Old 05-12-2021, 04:06 PM   #11
Contributing Member
Pahaska's Avatar
The fuses are standard automotive fuses. Available just about anywhere.
Old 05-12-2021, 05:48 PM   #12
Evans , GA
https://www.electricalhub.com/littel...xoCxGoQAvD_BwE
GAAirstreamr is offline   Reply With Quote
Old 05-12-2021, 09:01 PM   #13
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by GAAirstreamr View Post
That link is to a MAXI fuse it will not work on the Interstate DC distribution panel. You need an ATO fuse.
Size details in this Wikipedia page and attached diagram.
https://en.wikipedia.org/wiki/Fuse_(automotive)
- - Mike
Old 05-12-2021, 09:16 PM   #14
Contributing Member
Pahaska's Avatar
Littlefuse makes them in ATO size, as well. That is what I bought. I had to buy 5, if I remember correctly.
John W. Irwin
WBCCI #9632
Old 05-19-2021, 09:17 AM   #15
Half a Rivet Short
Carlisle , Pennsylvania
Hi
All of this "stuff" likes to be used every so often. Avoiding running this or that is a good way to set up for a "surprise" the first time it gets turned on. I'm not suggesting you have to run everything on the coach or trailer every week, only that something like once every 3 to 6 months might be a good idea.
We head over to a local state park every so often to use their water / sewer / power .... to do a good clean out of pretty much everything. The neighbors in the campground often think we are a bit nuts
Dirty Question mojoe7009 Waste Systems, Tanks & Totes 29 02-09-2017 07:43 PM
Help....Quick and Dirty Melody Ranch 1961 - 1963 Bambi 6 04-18-2006 11:35 PM
Airstream, my dirty little secret. krowsea Our Community 1 09-07-2004 02:06 AM
Dirty water system Michael W Waste Systems, Tanks & Totes 13 05-06-2004 03:12 PM
Tell me your dirty laundry... Safari Tim On The Road... 48 03-17-2004 01:32 PM
