Old 09-12-2019, 02:50 PM   #1
HOUSTON , Texas
Question about engine oil for Sprinter
Two questions, please.
First, I have a 2018 Airstream Interstate. Can someone tell me what brand and weight of engine oil is in my Sprinter as it came from the dealer/MB factory.
Second, the manual says 20K for the first service. Is this a reasonable mileage between oil changes? The Interstate is now 24 months in my possession and 8K miles. I've never had a vehicle that has gone so long between oil changes.
Your advice and assistance will be greatly appreciated.
John1048
John1048 is offline   Reply With Quote
Old 09-12-2019, 04:52 PM   #2
KSA63's Avatar
2020 30’ Globetrotter
Ramara , Ontario
According to my brief research, you should use a Mercedes specification 229.51 or 229.52 oil likely in a 5W30 viscosity.
https://www.idparts.com/oil-change-k...42-p-2462.html
My experience with German oil change requirements would suggest that they expect you to get your oil changed at the recommended interval OR yearly if you do not make enough trips to hit the actual mileage interval.
Hopefully someone else knows the official answers for you.
BTW, I also think that 20k miles is too many between changes.
Cheers
Kevin.
KSA63 is offline   Reply With Quote
Old 09-12-2019, 05:17 PM   #3
2013 Interstate Coach
Waterloo , Iowa
Somewhere on-line I found a list of all oils that meet the various MB specs. The oil I use is Northland Eurosyn 5W40. I buy it in 16 gallon drums (the only way they sell it) at a price of $5 per quart.
Titus is offline   Reply With Quote
Old 09-12-2019, 05:35 PM   #4
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
JOHN1048 - check with a Sprinter dealer. I think there is a time limit, like a year if you don’t drive enough to hit the 20,000 miles. But the ASSYST system should tell you when you need to change oil. If I only drove 4000 mile a year I’d get the oil changed once a year. But others might have better ideas.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 09-12-2019, 05:41 PM   #5
2018 Interstate Lounge Ext
LV , Nevada
JOHN1048 - there are many threads about this, search the forum using keywords "oil change". I will point you to one I am familiar with coz I asked the question on this thread . That should answer your questions (and more detailed discussions even beyond).
Alex AVI is offline   Reply With Quote
Old 09-13-2019, 09:34 AM   #6
Charleston , Arkansas
Its 12 months and up to 20,000 miles whichever is first.
TXWJ is offline   Reply With Quote
Old 09-13-2019, 11:17 AM   #7
2017 23' Flying Cloud
2023 27' International
Mesquite , Nevada
I have some advice, not about oil but rather oil filters. I learned the hard way DO NOT use anything but the correct oil filter from MB. Driving through Nevada in August the rubber seal on a major brand parts store filter failed. I lost 5-6 qtr. which was splattered throughout engine bay by belts etc. $450 to fix & clean up. The service writer at MB of Henderson said quote "once a week I have to tell someone don't put pep boys sh*t on your Mercedes Benz, it's made in China to fit multiple vehicles." After that I always carried several MB OEM filters in case my van needed service when I was not near a dealer.
Ken G is offline   Reply With Quote
Old 09-13-2019, 11:28 AM   #8
2024 Interstate 19
Fulton , Maryland
This is good advice. Cheap parts are mostly made in China and fail often. Beware!
- - Mike
Old 09-13-2019, 12:06 PM   #9
2014 Interstate Ext. Coach
Las Cruces , New Mexico
Based upon several MB Sprinter Service Reps recommendations from three states, and common sense, I believe, oil service interval of 15,000 or annually is the guidance I follow. Mann or MB Oil Filters with Mobil ESP Formula M 5W-30 have been the products that I have used since vehicle was new. https://europarts-sd.com/2007-2010sp...lchangekit.asp is a source for the oil and filter. NAPA offers same products less MB filters.
Note that the MB recommended viscosity changed sometime ago from 5W-40 to the current 5W-30. Also, for DIY, the Sprinter crankcase will take some volume from 12.5 to 13.2 quarts of oil. I learned early on that though most kits come with 14 quarts, fill first with 12 quarts, then allow some time before checking the dip stick before adding, very carefully any additional amount of oil! If the crankcase is overfilled, the dash computer will let you know! Changing the oil on this vehicle has been the easiest oil change of any vehicle I have owned.
JJKinnerup is offline   Reply With Quote
Old 09-13-2019, 12:31 PM   #10
2017 Interstate Grand Tour Ext
WILTON , CT
Oil
I have a 2017. It is when you go for an annual oil change that you realize you bought a Mercedes.
Havinfun is offline   Reply With Quote
Old 09-13-2019, 12:59 PM   #11
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Ocala , Florida
It’s 13 quarts of oil... and you should use the oil that is certified. So in oil alone you have 130-180.00 (depending where you buy it)...and then add the filter... we are not dealing with a 4 quarts oil change...
It is an expensive oil change no matter how you look at it.
I have done two so far in the 11k miles that I have with my AI... I will be changing it every 10k miles or every year
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 09-13-2019, 01:43 PM   #12
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
I bought an oil filter for my eco diesel from amazon.ca. It was shipped by a Chinese company and it took 2 weeks for delivery. It was 25%of the cost of an oem filter. It was stamped as shown in the photo. ???? Jim
Jim Flower is offline   Reply With Quote
Old 09-13-2019, 03:30 PM   #13
2018 19' Tommy Bahama
2015 Interstate Ext. Coach
South glastonbury , Ct
Sprinter oil
It was recommended to me by a Sprinter mechanic at Mercedes of 35 years to use 5w40 diesel truck full synthetic motor oil, Mobil 1 or Amazon 5w40 full synthetic diesel truck motor oil. Change the oil at 12-15 k intervals.
Not only is this oil better for the engine but it also reduces the diesel carbon emissions entering the dpf filter. This oil reduces blow through in the cylinders .
The 5w30 oil is not designed for Diesel engines according to this mechanic.
He also cautioned to always keep the DEF tank mostly full to avoid the cycle of warnings that come on when the DEF level runs low.
I own a 2016 Interstate.
pivotal1 is offline   Reply With Quote
changing oil 2013 Sprinter drgene Sprinter and B-van Forum 5 07-16-2018 06:10 AM
To oil or not to Oil woodyarn General Repair Forum 14 08-03-2012 08:05 AM
Does the amount of engine oil increase with the addition of a larger oil cooler? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-07-2009 08:56 AM
Engine Oil Question ViewRVs Mechanics Corner - Engines, Transmission & More... 12 05-25-2008 08:45 AM
Engine oil leak Robfike Mechanics Corner - Engines, Transmission & More... 6 01-04-2007 06:44 AM
