Old 09-26-2021, 10:20 AM   #1
2017 Interstate Grand Tour Ext
Marco Island , Florida
Propane Furnace
Furnace stopped working on current trip. Have plenty of propane as water heater and stove still works. A/C domestic unit is working but when furnace is selected the propane does not ignite and the fan does not turn in. Checked the fuses and rebooted the system to no effect.
Any help would be appreciated.
wildwilly. is offline   Reply With Quote
Old 09-26-2021, 04:58 PM   #2
2018 Interstate Lounge Ext
LV , Nevada
Are you sure you checked ALL the fuses. There's one 5A in-line.
Name:	Screenshot_20210926-154959_Samsung Notes.jpg
ID:	404944   Click image for larger version
Name:	Screenshot_20210926-155645_Samsung Notes.jpg
Alex AVI is offline   Reply With Quote
Old 09-27-2021, 06:04 AM   #3
Checked breaker
Thanks Alex. I checked the breaker and it will not reset. That must be the problem. Very unique breaker!
Old 09-27-2021, 06:48 AM   #4
Saluda372's Avatar
2021 20' Caravel
Plaistow , New Hampshire
Good luck.
Learning and enjoying as we go !
Saluda372 is offline   Reply With Quote
Old 09-27-2021, 06:58 AM   #5
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Have you checked at the breaker for power coming in and out? Furnace manual have a troubleshooting section?
Gary
GCinSC2 is offline   Reply With Quote
Old 09-27-2021, 09:04 AM   #6
2013 Interstate Coach
Waterloo , Iowa
Interesting. I didn't realize the furnace fuse was a breaker. I assume it was the 'normal old-style' glass tube type of fuse.
Titus is offline   Reply With Quote
Old 09-27-2021, 10:39 AM   #7
LV , Nevada
WILDWILLY - Not sure which 5A fuse/breaker is used in the 2017. But it may be the very common Dometic/Atwood 35791 Hydro Flame Furnace Circuit Breaker or similar. Regardless of brand, all of them are of the re-settable heat sensitive type and slow blow style - designed to protect the blower motor. And due to their location on the furnace, the heat of furnace cannot affect their operation. Also, short amperage spikes will not cause a trip. The motor has to have been producing an excessive and prolonged amperage draw to trip it. So some issue still exists. Unless the breaker itself could be bad?? Pic of 2 versions of 5A Dometic/Atwood attached
Stuck propane valve on full propane tank. BoatNutG2 Airstream Lifestyle 3 09-15-2019 09:22 PM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Newbie Advice on Propane and Propane Accessories Socal1 LP Gas, Piping, Tanks & Regulators 1 07-15-2013 12:36 PM
