Old 03-26-2020, 10:05 AM   #1
Luckysnuck's Avatar
Liberty Township , Ohio
Preferred Lubricant - Rear Bench Seat Screw Lift Mechanism
Hello Friends,
Interested in anyone's opinion on a preferred lubricant for the rear bench seat "screw-lift" mechanism?
Thanks in advance...stay well!
Name:	2018 AIGT - Rear Bench Seat Screw Lift.jpg
Luckysnuck is offline   Reply With Quote
Old 03-26-2020, 10:11 AM   #2
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
White lithium grease, applied sparingly. Same thing you'd use on garage door openers. One application should last for many years.
But you've reminded me, I need to grease both.
rowiebowie is offline   Reply With Quote
Old 03-26-2020, 12:23 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
I would use Super Lube
CRH is offline   Reply With Quote
Old 03-27-2020, 06:53 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I would keep it dry, clean and slippery.
Obrigado, hora de descansar.
Tahawus
Old 03-30-2020, 01:44 PM   #5
rowiebowie's Avatar
2012 Avenue Coach
Originally Posted by ROBERT CROSS View Post
Darn, I'm late to the game again. I only recently bought a can of the newer WD-40 "Speicalist" spray. Only mine is the "water resistant silicone lubricant". Now your telling me WD-40 now has a "Dry lube PTFE spray". Now I've gotta make more room on my shelf (and there ain't much room left there).
Old 03-31-2020, 08:25 PM   #6
swilly43's Avatar
escondido , California
Rowie Bowie, +1
swilly43 is offline   Reply With Quote
Old 04-01-2020, 10:46 AM   #7
2013 Interstate Coach
Raymond , Iowa
Do you use a solvent to remove as much grease as possible before using the dry lube?
I have long noticed a loud squeak/rubbing noise when raising and lowering the seat. Finally got around to looking at it. The track was rubbing on the wooden piece at the front of the box beneath the seat. This is the piece that the 12V fuse box is mounted in. I put a bit of lithium grease on the wooden notch that the track sits in and it is now quiet.
Titus is offline   Reply With Quote
Loose Dinette Bench Seat Cold Beer Cabinets, Counter Tops & Furnishings 14 06-30-2017 04:24 PM
I have put a TV on the wall behind the bench seat and table I need to get the antenna Trident Land Yacht/Legacy Motorhomes 34 09-07-2015 08:47 AM
Caravanner bench seat design needed Jeremy9107 Cabinets, Counter Tops & Furnishings 5 07-21-2013 11:14 PM
