Originally Posted by urnmor
Was your AS plugged into electrical if not you must be sure both the TV and DVD are plugged into the inverter outlets and the inverter button is on. This will allow it to run off of the batteries
Nothing has changed with AI. It sits in the drive way, and I intermittent plug it into the house when I work on it and run the generator every so often between big trips. Only difference is, this morning when I went to take it out, I noticed the TV and DVD wouldn't turn on. I did check the inverter.
Thx for the reply!
