RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 09-21-2018, 06:49 PM   #1
Moncks Corner , South Carolina
Outside TV Mount
Looking for suggestions and pictures preferably, of an outside TV mount on an Interstate. Setting a TV on top of a table somehow takes away from the classy look of the Interstate.
Delores is offline   Reply With Quote
Old 09-22-2018, 04:26 AM   #2
2019 Interstate Lounge Ext
Doylestown , Pennsylvania
I would love to see this too.
Cats52 is offline   Reply With Quote
Old 09-22-2018, 06:39 AM   #3
What size of TV were you hoping to see / mount?
Also, were you thinking side or rear?
Someone else on another thread made it so that a TV was temporarily mount-able in the rear of the Interstate, such that it was view-able out the doors (for tailgating). But that was a while ago, and I can't remember the thread.
Old 09-22-2018, 12:19 PM   #4
iaqstuff's Avatar
2013 Interstate Coach
Yarnell , Arizona
We swing the lounge TV around so it can ge seen and heard from the curbside lounge window. May not be classy, but we don`t have to haul around a "portable."
iaqstuff is offline   Reply With Quote
Old 09-22-2018, 12:29 PM   #5
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
I have one designed in my mind that would work great. But. It would involve mounting a aluminum channel to the side of the unit. This could be powder coated to match the color of you Interstate.
Old 09-22-2018, 01:39 PM   #6
Iím thinking more on the passenger side near the rear. It would be close to the outlet and cable box already on the side. Also it would need to clear the slide door when it opens
Old 09-22-2018, 01:48 PM   #7
Tv size 24-32Ē. Nothing too big.
Old 09-22-2018, 10:03 PM   #8
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
What about using a small projector and a screen? Easier to setup and store...
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 09-22-2018, 10:41 PM   #9
Boxster1971's Avatar
Fulton , Maryland
Outside TV Mount
I installed a Camco 57268 Mounting Rail for my grill on the passenger side behind the rear wheels of my Interstate. It is directly above the LP Fill Panel. This rail could be used to mount a TV much like suggested by GMFL.
This page from Walmart shows the grill and table stand that can also be mounted on the rail.
https://www.walmart.com/ip/Camco-Oly...Grill/29764622
This page from Amazon shows the mounting rail and one version of how it can hold a grill on side of an RV.
https://www.amazon.com/Camco-57268-M...ttl_B0014JBYTC
I'll have to dig into my photos to later post a photo of what it looks like on my van. Using this mounting rail you could fashion a TV mount setup.
- - Mike
Old 09-23-2018, 01:21 PM   #10
Fulton , Maryland
Here are some photos of the mounting rail, grill holder and installed grill on my Interstate. This mounting rail could also be adapted to hold a TV for outside viewing.
ID:	323434   Click image for larger version
- - Mike
Old 09-23-2018, 07:56 PM   #11
Boxster1971, any concern with this setup damaging the outside. Is there a brace behind the aluminum side for this bracket to attach to? This would be a workable option I think.
Old 09-23-2018, 08:12 PM   #12
Iím trying to use a flat screen tv with a built in DVD player that I have already.
Old 09-23-2018, 08:27 PM   #13
wachuko's Avatar
Orlando , Florida
Thumbs up
Ahhh, got it!
Safe travels!
Wachuko
WBCCI #26769
Old 09-24-2018, 09:02 AM   #14
wachuko's Avatar
Orlando , Florida
Question
I sent Mike a couple of questions on his setup... one was about the rail and if there was a need for internal reinforcement to avoid the sheet metal bending/getting damage from use...
Safe travels!
Wachuko
WBCCI #26769
Old 09-24-2018, 09:18 AM   #15
Wachuko, that would be my concern also.
Old 09-24-2018, 12:42 PM   #16
Fulton , Maryland
DELORES - I'll post below what I sent via PM to wachko and add that I think this mount is OK for a grill or a 19-21" TV mount. Both are close to the same weight.
It came white and I painted it silver. It is attached with four SS sheet metal screws and some sealant. I did not remove the interior panel. Just estimated that the area behind the mount was clear. I've had the grill mounting set-up over four years now and use it on nearly every trip. It is holding up just fine with no issues.
I did notice that the grill mount has changed. Mine folds up for storage in the grill case. It doesn't look like the new one will fold. But the new Olympian 5500 grill would be easier to use as it has built in table legs. It looks like an overall improved design.
The only problem I've had with my grill was the thermometer. It got damaged and I replaced it with one from Weber. I also added a latch to the lid to keep it locked closed. You can see the latch if you look close at my posted photo. I noticed the new model already has a lid latch and a better thermometer - nice improvements.
- - Mike
Old 09-24-2018, 05:26 PM   #17
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
MIKE - Nice grill. Now I know where to get burgers at Alumapalooza.
DELORES - Not exactly outside setup, more of a inside but viewable outside, just another idea.
Alex AVI is offline   Reply With Quote
Old 09-24-2018, 06:29 PM   #18
Thanks Boxter1971
Old 09-26-2018, 09:18 PM   #19
Alex AVI's Avatar
DELORES - the tv you will use is not heavy at all. Something like these tire steps are easily adaptable to be portable seats or tables or work area (for my bike work when on races). You could easily bolt a VESA tv bracket on it and mount the whole contraption behind tv, so all you do is pull itbout and slide over tire. It is portable, adjustable, very light, take up little room, supports lots weight, and usable on all 4 corners of van and always out of the way of doors
ID:	323801   Click image for larger version
Old 09-27-2018, 08:54 PM   #20
Wow, this may be exactly what I need. I will order one and try it out, but I think this is a great solution.
BatteryMinder - to mount or not mount, that is the question. Ruffn It Generators & Solar Power 4 12-11-2017 03:51 AM
2017 Flying Cloud 30 ' Hub Mount / Stud Mount question twolanehwy General Repair Forum 3 09-24-2017 03:03 PM
Outside rear tire mount BRAND NEW jet1 Airstream Classifieds 0 05-16-2016 03:12 PM
Stud Mount TV Mount on Shower Wall??? BASE729 Audio, Video & TV 0 11-29-2014 05:31 PM
Flush Mount or Surface Mount Zac&Kristin Water Heaters, Filters & Pumps 10 01-13-2008 07:59 PM
