Originally Posted by randkell1
I figured out what the problem was. The main power disconnect needs to be on to use the external quick disconnect. FYI - The regulator was removed when I replaced the hose to the new quick disconnect hose.
Ah, yes, that might be related to the power-driven solenoid for the propane switch. That little booger sucks power, unbeknownst to many, to keep the propane valve open. If there's no power to that switch and the solenoid behind it, you can't get any propane.
Also, if you find you've got a phantom power vampire drawing your batteries down when you think everything is off except the "use" switch, check that propane switch and turn it off. The power this solenoid draws to stay open adds up over 24 hours.
