Old 03-09-2019, 12:09 PM   #1
Libertyville , Illinois
Onan is Dead
Hi Folks,
The genset in my 2015 GT is dead. The start button doesn't light and nothing happens when I try to start. Also tried the button on the actual generator where I can hear a slight click when the start light flickers on then off. I'm getting error code 36. Searched the forum and haven't found any help other than it's likely a fuel supply issue. Full tank of LPG, stove and furnace both work. Coach batteries fully charged and have power to the Onan. Any ideas?
Eric
Schmitte is offline   Reply With Quote
Old 03-09-2019, 12:40 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
My guess bad ground or corroded battery connection.
You may have 12V but not enough current (amps) getting to the generator starter.
Garry
Old 03-09-2019, 01:17 PM   #3
Thanks Garry. The terminals were a little corroded. Just started raining here so Iíll clean them up tomorrow and see what happens
Old 03-09-2019, 02:26 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Always start with the cheapest stuff and work your way up.
Check fuel stock and supply lines
Clean all electrical connections, including grounds; (make sure to disconnect batteries first before cleaning any connections on the gen set).
Check all fuses, switches, relays and circuit breakers.
Then start checking hardware.....like starter.
It's usually the cheap stuff........
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 03-09-2019, 04:57 PM   #5
Thanks Tony. I donít recall seeing the ground wire/ connection when I was under there today. Is it easy to spot?
Old 03-10-2019, 09:26 AM   #6
2013 Interstate Coach
Raymond , Iowa
On mine the '+' and '-' cables from the house batteries are outside the generator enclosure near the bottom of the front curb side. I would start by removing these cables and cleaning the connections. If that doesn't solve it you could try the other end of those cables. But the other end is inside the rig and thus less likely to get dirty (though the connection could be loose). No reason to check the fuel lines unless/until it fails to start when turning over.
Titus is offline   Reply With Quote
Old 03-10-2019, 11:41 AM   #7
I guess it was more than a little corroded!
Hard to believe this happened in just one winter
Old 03-10-2019, 11:46 AM   #8
2011 Interstate Coach
Evansville , Indiana
A picture is worth a thousand words. Glad you found the problem!
BurntAsphalt is offline   Reply With Quote
Old 03-10-2019, 12:24 PM   #9
2007 22' International CCD
When you get the lug replaced, be sure to clean the terminals thoroughly with a small brass or stainless steel wire brush. Use Marine grade terminals made of tinned copper, and use adhesive-lined heat shrink on the cable and lug to seal out moisture.
When you put it all back together (ending with the negative lead), spray the connections with the red battery terminal sealant to keep moisture and acid vapor away from the terminals.
<2mo Old - Dead Batteries Dead Electricals GT2018WA Electrical - Systems, Generators, Batteries & Solar 9 05-29-2018 01:48 PM
house battery seem dead/ shore power dead joe rv guy Sprinter and B-van Forum 29 12-26-2016 12:36 PM
Onan 5500 quits and now battery is dead mossyoaks Generators & Solar Power 0 10-08-2016 09:03 PM
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
