Originally Posted by dapolrbear
... I asked how they're planning to evacuate the propane, dealer has no idea. ....
I had to burn ours off when work needed to be done to the tank system. Which is a fairly tedious process of sitting there running the generator. At the time, we were in the midst of electrical upgrades and I was unable to put the generator under load (with the roof a/c). So it was a drag to sit there for several sessions of multiple hours until the generator finally sputtered out of life.
For a time, I tried running the stove to accelerate the process, but I do not recommend this. The stove is not designed to be run for long periods, and could get damaged. So you might want to advise them not to try that trick.
