Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 06-09-2018, 12:03 AM   #1
2017 Interstate Lounge Ext
Temple City , California
No propane flow
Propane is not flowing to the stove and gen. Tank is 2/3 full according to the lights on the panel and the gauge on the tank. Exterior toggle switch is on, the solenoid is hot to the touch when switch is on and cool when off. So does that mean the switch and solenoid is working? I'm guessing its a regulator problem, I can't seem to find the regulator near the tank. Anyone know the part number or where I can get a replacement besides the dealer?
dapolrbear is offline   Reply With Quote
Old 06-09-2018, 06:59 AM   #2
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
Your profile says you have a 2017 Interstate. It should still be under warranty.
Dealer replaced my LP regulator on a recall. The regulator is under a cover near the shut-off valve on my 2013 model. Yours should be in same location but you will have to remove some metal to get to it.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 06-09-2018, 07:32 AM   #3
Ours is an older unit, so our propane system will differ in some details, but here's a pic showing a general configuration.
Old 06-09-2018, 11:19 AM   #4
What is the warranty period on the Interstate? I know the chassis or anything related to Mercedes is 3yr/36k miles. I thought the Airstream/motor home portion was only one year? I took delivery 8/16 it's been over a year and my dealer is ridiculously backed up I didn't want to leave it there for a few weeks. Although after looking at the location of the regulator I may have to bite the bullet and make an appointment with service.
Old 06-09-2018, 11:42 AM   #5
There’s a preferred dealer program where they are supposed to get to you within 48 hours or something. Someone else might chime in with details. I’m on my phone.
Old 06-09-2018, 12:56 PM   #6
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
On my Avenue, I can tell the valve is opening because I can clearly hear a hollow-metallic-click that is distinct from the "click" of the on/off switch.
If your valve is not located close enough to the switch for you to hear it open, have someone listen near the valve while you operate the switch. If they don't hear the click at the valve, then it may be stuck.
But I agree with others, get it looked at while you have it under warranty. I've never felt my propane solenoid to check for heat, but I don't like that your's is hot to the touch.
rowiebowie is offline   Reply With Quote
Old 06-09-2018, 06:04 PM   #7
2024 Interstate 19
Fulton , Maryland
Airstream warranty is also 3 years/36,000 miles. Getting at the regulator is not an easy tasks and best left to someone familiar with working on LP systems. Also as others have mentioned you should be able to hear the modest "klunk" sound when you turn on the LP switch. I have a second switch inside and I can clearly hear it when I turn on the valve. You might need to be inside in back of van to hear it. If you don't hear it that could be your problem. I've never checked my valve for heat when ON so I can't be sure if that is normal.
Understand not wanting to wait for dealer to look at it. If it is the dealer that you bought it from I'd recommend you try to get them to give you some priority so you don't loose too much of the summer season.
Good luck!
- - Mike
Old 06-10-2018, 05:44 AM   #8
2013 Interstate Coach
Waterloo , Iowa
I think that a 'clank and heat when the switch is on is good means that the solenoid is working. The open solenoid draws about 0.5A and this would heat the solenoid. I quess the problem is with the regulator. (Are you sure there is propane in the tank? Don't trust the gauges - use hot water to check.) Should be a simple fix (replacement) that any RV shop can do, but may take a while to get it done at Airstream under warranty.
Titus is offline   Reply With Quote
Old 06-10-2018, 10:49 AM   #9
Just went to get some propane, just incase the gauges were wrong. It wouldn't take any propane and nothing was coming out of the bleeder valve. Would a bad regulator effect propane filling? Is there another valve stuck?
Old 06-10-2018, 03:21 PM   #10
Waterloo , Iowa
The bleeder port is completely separate from the regulator. There is a standpipe inside the tank that leads to the valve at the fill panel. The bleeds ve is opened when filling. Gas (vapor) comes out until it is 80% full, then liquid comes out. When they see liquid they stop filling.
Old 06-10-2018, 04:01 PM   #11
rowiebowie's Avatar
2012 Avenue Coach
Even though I know zip about propane, had the person filling your tank been knowledgeable, the symptoms you describe should have told them what was wrong. Seek a propane station staffed with trained personnel.
Good luck.
Old 06-11-2018, 12:09 AM   #12
Nothing came out of the bleeder valve when filling, tank is full, switch is working, solenoid is clicking, any other components to consider? I'm taking it in on Tuesday and want make sure I tell service department exactly whats happening so maybe they can diagnose the problem faster and I don't have leave it there for weeks unplugged killing my batteries.
Old 06-11-2018, 05:50 AM   #13
Aircruiser's Avatar
2012 Interstate Coach
Westerville , Ohio
Ahhh, a puzzle to solve. This link takes you to a great description of how your system works. http://roadtreking.com/innards-rv-propane-tank/
If you really get nothing out of the bleeder--no hiss of escaping gas vapor when the knob is loosened--AND you have no gas to your appliances, then it would appear that you have no propane, which would mean that two other things aren't working--the overfill protection device is stuck closed and won't let propane enter the tank, while at the same time, your propane level indicator is stuck or malfunctioning at the 2/3 level. If you do get vapors hissing out when you loosen the bleeder, then you're back to suspecting the shutoff valve being stuck or a stuck valve in a regulator, if that's even possible. The last paragraph mentions a slam-shut valve that stops gas from leaving the tank in the event of extreme loss of gas down stream. That may be your culprit.
Aircruiser is offline   Reply With Quote
Old 06-11-2018, 08:02 AM   #14
Waterloo , Iowa
As I understand the LPG system (from the Roadtrek link), the overflow protection device (OPD) is separate from the bleed line. If the OPD is working then it shuts off the filling when the tank is 80% full. The bleed line is connected to the bleed valve at the fill panel. The stand pipe (that feeds the bleed line) is also at the 80% level. So if the OPD is set a bit below 80% and the bleed pipe at 80% then the OPD will stop the filling before you see liquid out of the bleed valve. If the OPD is a bit above 80% and the stand pipe at 80% then the person doing the filling will see liquid propane at the bleed valve and he will shut off the filling pump. I suppose it is possible that the OPD is stuck closed and that the tank is actually empty. But the gauges would have to have failed too. There is a small (very very small) likelihood of having both the OPD and gauge(s) fail at the same time (they are separate systems). But to be sure I would pour hot water over the tank and see at what point the side of the tank goes from warm (vapor) to cold (liquid). This should be at the 80% point. If it is warm top to bottom then the tank is empty even though you think it is full. If it goes from warm to cold near the top (80%), then your problem is (probably) with the regulator. As Bob mentions above, there might be another valve that shuts if the flow is too high.
Old 06-11-2018, 08:44 AM   #15
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi dapolrbear,
We are very sorry for the issue that you are having with your 2017 Interstate. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
You can also reach Airstream Customer Service and Technical Support at customer_support@airstream.com
We look forward to helping you get this resolved. Thank You.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 06-13-2018, 11:40 AM   #16
Dropped off at the dealer yesterday and tech suspect the solenoid is bad, stuck closed. Can't change the solenoid because the tank is full, no way to empty tank safely and no shut off valve between tank and solenoid. Any suggestions?
Old 06-13-2018, 12:12 PM   #17
Waterloo , Iowa
Do you know the make and model of the solenoid? There might be a way to move the solenoid mechanically (relax valve spring tension via a screw on the top of the solenoid?) but you would need to look at the drawing to be sure. Did you or the tech try tapping on the solenoid when it is energized to see if you can jar it loose?
Old 06-13-2018, 12:18 PM   #18
rowiebowie's Avatar
2012 Avenue Coach
You're "no propane" problem is annoying, but not as annoying as your bad luck getting a qualified person to diagnose your problem.
Did you take Airstream up on their offer to speak to their tech?
Old 06-13-2018, 01:15 PM   #19
Don’t know the make and model. I’ve tapped on it at home but nothing happened. I don’t think the tech is confident enough to work on it with a full tank.
Old 06-13-2018, 01:23 PM   #20
Tell me about it. I spoke to Jeremy at Jackson Center, he is great to deal with and is on top of it. He’s called the dealer the day before my appointment to let them know what’s going on and that they have his full support. Problem is the message gets lost at the dealership. None of the service writers or techs are aware that he’s called.
I guess I’ll just give them a couple days fiddle with it.
Here's the problem, what's the diagnosis: propane flow eubank LP Gas, Piping, Tanks & Regulators 23 09-12-2012 08:25 PM
Flow Thru Exhaust and Muffler LKappenman Mechanics Corner - Engines, Transmission & More... 17 09-22-2009 11:29 AM
Shower Regulator or Back Flow Valve GStephens Fresh Water Systems 19 07-08-2004 09:56 AM
Water flow question... Sneakinup Waste Systems, Tanks & Totes 1 05-19-2004 06:20 PM
No water flow Michael W Plumbing - Systems & Fixtures 4 10-12-2003 08:26 PM
