Old 07-29-2019, 07:59 AM   #1
X New Yorker
X New Yorker's Avatar
2013 Interstate Coach
Springfield , Massachusetts
No Air Conditioning
My air conditioning died at the International Rally which I then had to cut short (I just could not handle the 100+ days in the van). The RV tech, that worked on it at the rally, advised that I needed a new fan which we replaced and now it seems it was the compressor.
Question can I replace the compressor or should I just replace the unit? The band is Domitec and it is ungodly noisy when running.
Is there a better quieter reasonably priced unit out there?
Thank you for the feedback.
X New Yorker is offline   Reply With Quote
Old 07-29-2019, 08:26 AM   #2
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Yes. Finally new and quieter ac units are available like the Coleman Mach 10 NDQ. See post #80 in the recent thread below
http://www.airforums.com/forums/f240...ud-121339.html
Good luck.
rowiebowie is offline   Reply With Quote
Old 07-29-2019, 09:10 AM   #3
rowiebowie's Avatar
2012 Avenue Coach
When you change out your ac, consider a 15K btu unit rather than the standard 13.5k unit. I think you'll find increased efficiency in the newer units will allow a size larger and still probably pull an amp less than your old unit.
I did this on my 2012 Avenue and it is not over-sized (too much ac) to go to a little bigger unit even when running on cooler days or nights. Unit still cycles nicely yet it's nice to have a bit more cushion for quicker cool down on hot ones.
Old 07-29-2019, 09:28 AM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Replace the unit rather than dumping a bunch of parts into it. You might replace the compressor and then find that the control board has issues ....
Old 07-29-2019, 05:04 PM   #5
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
XNEWYORKER - I have no experience with rv a/c problems yet. But I have friends who are licensed HVAC technicians. In my personal opinion only - I would not enlist their help in trying to evacuate/recover the lines to replace a compressor in an old unit that I already consider "ungodly noisy" to start with. My unit is only 1 year old, and like you I too consider it horribly noisy to the point where I would replace it today if certain other criteria could be met. I will live with it until then. But if it breaks tomorrow, I would throw it into the garbage bin and buy a quieter one. I liken rv a/c units to home window units = disposable = clip wires, remove 4 bolts, throw away. You got the perfect excuse to upgrade I will be jealous of your new & quieter unit.
Alex AVI is offline   Reply With Quote
Old 07-30-2019, 02:37 PM   #6
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Best van ac is from Advanced RV in Ohio. They will install it is more powerful and quieter.
PSchw is offline   Reply With Quote
Old 07-30-2019, 03:37 PM   #7
Alex AVI's Avatar
PSCHW - No argument that it is quieter and probably the quietest non-ducted unit out there. But excellent discussion on the other thread about the inner workings of the ARV/Houghton a/c. Good thread to follow for anyone considering the ARV/Houghton.
Old 07-30-2019, 05:34 PM   #8
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
This sprinter forum is talking about this unit for vans. Would it work in a travel trailer?
Old 07-30-2019, 06:26 PM   #9
Alex AVI's Avatar
STEVESUEMAC - If you're asking about the ARV/Houghton A/C, it should work on TT. No reason I can see why not. It is a direct drop-in replacement for our Dometic Penguin II. In fact, due to an on-going concern that it does not work optimally while van is moving and currently is supposed to be made for static use, it is even more suited for TT.
Old 07-31-2019, 07:28 AM   #10
rowiebowie's Avatar
2012 Avenue Coach
I might need double gaskets and drainage cups or whatever the trailers need for condensation water.
New AS Air Conditioning - Does It Work? DreamStream Furnaces, Heaters, Fireplaces & Air Conditioning 14 02-27-2004 07:01 PM
air conditioning cowling and vent disintegration Rickj Furnaces, Heaters, Fireplaces & Air Conditioning 7 12-30-2003 01:04 PM
Air Conditioning Help Please!!! 85MH325 Furnaces, Heaters, Fireplaces & Air Conditioning 26 08-16-2003 08:58 AM
Air Conditioning Leak ccphoto Furnaces, Heaters, Fireplaces & Air Conditioning 5 06-15-2003 09:18 PM
Fantastic Fan or Air Conditioning??? Charcigar Roof Vents, Skylights & Fans 15 01-21-2003 08:19 PM
