Old 08-03-2021, 06:44 PM   #1
2021 Interstate 24GT
bellefontaine , Ohio
No AC
Started generator and AC not working. Checked fuse and 15 amp circuit breaker tripped and 10 amp fuse for fantastic fan, reading light, furnace blown. Reset breaker but fuse blows as soon as touching socket. Called AS service, no help
Any suggestions? Thank you
pdodds is offline   Reply With Quote
Old 08-03-2021, 07:25 PM   #2
2021 25' Globetrotter
Oviedo , Florida
I guess my first question would be does the AC work off shore power? Will the furnace and fan work off coach batteries (I’m not familiar with your vehicle, but I assume those things work off 12 V.
jondrew55 is offline   Reply With Quote
Old 08-03-2021, 08:09 PM   #3
2021 27' Globetrotter
Malibu , California
What size of generator? What altitude are you at? Does your AC have a micro-air soft start?
CMHM is offline   Reply With Quote
Old 08-03-2021, 10:13 PM   #4
I probably wasn’t clear but I have interstate grand tour so what ever size generator that comes with the coach
Old 08-03-2021, 10:16 PM   #5
Ac, furnace or reading lights, fan work on shore power either
Little frustrating that I live 20 miles from factory and the are booked till January
Old 08-04-2021, 04:37 AM   #6
2020 Interstate 19
Hammondsport , New York
Are you saying they work or don’t work on shore power? The “either” threw me off.
I got the same response from Airstream HQ yesterday. Seems like (1) a lot of people have problems, (2) they haven’t kept up with support and maintenance demand. Probably both.
CavemanB is offline   Reply With Quote
Old 08-04-2021, 08:33 AM   #7
Donít work either way. Sorry I missed a word. 😂
Unbelievable I live so close and even worked there years ago. Owned 4 airstreams and canít squeeze me in for a look.
Old 08-04-2021, 08:42 AM   #8
2019 30' Classic
2021 Atlas
Charlotte , North Carolina
Try this, turn off all circuits and plug into shore power. If you trip then, you have a short coming in, like the plug to the panel. My guess is that is unlikely but possible. Then turn on one circuit at a time to see which line has the short until you find one that trips. Converter/inverter? Good luck. Hopefully you can run without whatever has the short. If it is the Magnum unit, you will need a fix before you can do anything.
2019 Classic and 2022 Atlas and 2 cats
LilPeanut is offline   Reply With Quote
Old 08-05-2021, 04:47 AM   #9
Update. Now in service repair so will hopefully see what problem is. Thank you
Old 08-05-2021, 05:45 AM   #10
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Recently our AC went bad and I am now in the process of replacing it. It could be one of three things a board went bad The relay (wrong name) or the compressor. If you have a heat pump and both the aC and heat pump does not work I fear you will need to replace the unit. However if the HP works it more than likely a board or the capacitor
urnmor is offline   Reply With Quote
Old 08-06-2021, 08:05 AM   #11
found problem. short in wiring on bathroom fan. fixed! thank you AS service!
Old 08-06-2021, 12:45 PM   #12
urnmor's Avatar
Berlin , Maryland
That is good news. I am not that lucky as I am having a new Ac put in. Not sure what caused the problem however when the technician took the he cover off he found a water hose and also electrical outlet that was not connected I am not even sure why an electric outlet would be there
