Old 03-15-2020, 04:26 PM   #1
GoingPhishin's Avatar
2017 Interstate Grand Tour Ext
Castle Rock , Colorado
Need some install advice on the Victron BMV-712
I spent the weekend upgrading to the Victron 100/30 charge controller and BMV-712 battery monitor.
The charge controller seems to work. Here is a photo:
The monitor, however, does not seem to work. I do not have an amp reading and the time remaining says infinite.
Here is how I setup the shunt. I have no idea about the white wire to the post. There was a cut white wire that was not connected to anything. I thought it might be a ground? In any event, I connected it the negative post. Any thoughts on this?
GoingPhishin is offline   Reply With Quote
Old 03-15-2020, 07:24 PM   #2
2017 27' International
Lake Havasu City , Arizona
BMV-712 hookup
It's not possible to tell from that photo how you wired the shunt.
The basics: ALL the wires that were on the negative battery post must be relocated to the "load" side of the shunt. And only one wire must be connected from the negative battery post to the "battery" side of the shunt. The fact that the BMV-712 is seeing battery voltage but not seeing current flow suggests that this is not wired correctly.
Also, the skinny wire with tiny inline fuse holder that came with the BMV-712 must be connected from the "+B1" terminal on the side of the shunt to the battery's positive terminal. Since the BMV-712 can read battery voltage, I'm guessing this was done correctly.
I don't know what the "cut white wire" you're talking about is. It doesn't sound like something that came with the BMV-712. Did you follow it to see where it originated? In general, if you don't know what a wire is for, I wouldn't recommend connecting it to anything. And in any case, no wire should be connected to the battery's negative post, except for the jumper from the shunt.
If you're not sure about all this, see figure 3 of the Quick Installation Guide, ignoring the dashed-line parts.
Paprika is offline   Reply With Quote
Old 03-15-2020, 08:59 PM   #3
Thanks, Paprika. In all honesty, today was one of those extremely frustrating ownership days. I felt like throwing my whole tool box off a cliff.
Here is a better picture of the shunt. The white wire I had attached is circled in yellow. I cut it after I attached it (mostly out of frustration).
Old 03-15-2020, 09:40 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Are you certain the CBL8 cable is not the one coming from the battery?
wulfraat is offline   Reply With Quote
Old 03-16-2020, 05:43 AM   #5
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Did you program the settings on the BMV-712 for your battery? --Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 03-16-2020, 06:15 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Your status screen looks the same as ours, fully charged, not charging with no draw. NPF🤓
Obrigado, hora de descansar.
Tahawus
Old 03-16-2020, 06:45 AM   #7
Paradise , Texas
It looks like you are in an interstate. Your batteries are under the van. Unless you have relocated them. Just the connection at the Magnum is not enough to give a proper load or capacity reading. You really need to isolate the negatives from the battery to the shunt, even if it means relocating shunt, or running new cables.
Crackerman is offline   Reply With Quote
Old 03-16-2020, 08:10 AM   #8
I am pretty sure that it is not. I don't think I would have a voltage reading if it was not. I'll double check.
I believe I did. See photo:
Thanks. When I turned on the super fan or tried some other load, the reading did not change. I assume that it would have shown some amp changes.
Yes, it is an Interstate. I believe that the negative directly from the battery is isolated to the shunt. The shunt then is connected to the common negative post which then goes to the Magnum (I think).
Old 03-16-2020, 10:40 AM   #9
jhayesas's Avatar
Kansas City , Missouri
I'm following this thread closely and once you work out the details, I would like to get this installed in my rig.
jhayesas is offline   Reply With Quote
Old 03-16-2020, 11:23 AM   #10
2013 Interstate Coach
Indianola , Iowa
I installed this a few weeks ago. You have to rewire your batteries so they are wired in parallel and not to a common negative and a common positive.
nateallen80 is offline   Reply With Quote
Old 03-16-2020, 08:48 PM   #11
wulfraat's Avatar
It could be a bad shunt, its possible. In my most recent install the 712 was giving erroneous readings. Replaced and all was well. If you turkey have everything wires correctly and have verified with the voltmeter at various points then try swapping the bmv.
Old 03-17-2020, 10:47 AM   #12
Wulfraat was correct (partially). Turns out the CBL8 is the ground for the battery. For some reason it goes to the ground buss. I moved it to the shunt (along with the negative) and everything seems to be working.
Old 03-17-2020, 05:15 PM   #13
wulfraat's Avatar
Cool
Old 03-25-2020, 11:53 AM   #14
2016 30' International
redondo beach , California
A happy ending! Listen to the rat.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 07-18-2020, 09:32 AM   #15
jhayesas's Avatar
Can you post an updated picture of your install?
Old 07-18-2020, 09:54 AM   #16
Sure. I am away from my van right now. Give me a couple of days.
I ended up having a bad shunt that I had to send back as well as a blown battery fuse. That really messed up the install. Other wise, this should have been really straight forward.
Old 07-24-2020, 04:39 PM   #17
jhayesas's Avatar
I ordered a Victron SmartShunt today and will be installing it next week. My environment looks like below so if anyone has any input or advice, that would be greatly appreciated.
Old 07-24-2020, 04:48 PM   #18
I don't see a negative buss bar, all neg wires go there.
The negative battery wire goes to the input side of shunt with the output side wired to the buss bar.
That's how I wired, seems to work properly, am I wrong?
Tahawus
Old 07-24-2020, 05:11 PM   #19
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
Hi Bob, I ran a single lead from the battery neg to the Shunt (BATT ONLY) and then the load side went to the negative bus. I ran the battery pos to the positive distribution block and the hooked up my solar input the the (LOAD) side of the shunt and the positive distribution block.
That looks like the negative bus in your photo. I would think that one of those heavy gauge black wires goes to the (LOAD) on you shunt. ??
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Old 07-24-2020, 05:29 PM   #20
The arrow points to the negative wire from the batteries.
The shunt is wired to that wire down stream not visible, on the floor.
Tahawus
Victron BMV-712 Battery Monitor Shunt Install location 5150mike Electrical - Systems, Generators, Batteries & Solar 35 06-25-2020 05:50 AM
Victron BMV-712 Smart Battery Monitor Install&Review lzhome Generators & Solar Power 0 10-03-2019 05:05 AM
Victron BMV-712 Install Question Rounder44 Electrical - Systems, Generators, Batteries & Solar 25 11-23-2018 05:53 PM
Question regarding Victron BMV-712 billrector Batteries, Univolts, Converters & Inverters 26 05-30-2018 03:21 PM
Victron BMV-712 install in 2017 30 International dmcgaugh Batteries, Univolts, Converters & Inverters 3 03-09-2018 12:24 AM
