Old 12-27-2019, 07:00 PM   #1
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Neat wire connectors
I have been happily using common crimp terminals for my wiring changes up to now. I have used a lot of yellow, blue, and red butt connectors. That changed with my purchase of a Goal Zero 1000 that makes use of Anderson Power-Pole PP) connectors. Not having used that connector to date, the GZ got me digging into the information regarding the Power-Pole connectors. I really like them
Common PP sizes are 15, 30, and 45 amps. I have the 12v max cable for the GZ that will supply 40 amps of 12v to my AI 12v system. The output connector on the 12v max is a PP 45 amp pair.
The PP connectors are much more secure than anything I have used before and are arc-resistant when plugging or unplugging. They can be applied without a special tool, with care, but I went ahead and ordered a $35 crimping tool. Accessory cables with the PP ends are expensive, but the raw connectors are very reasonable.
I had been intending to put a switch in the hot lead from the solar. Instead, I'll just insert a 45 amp PP in the line.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 12-27-2019, 07:59 PM   #2
2018 30' Classic
Williamsburg , VA
I have been using posi lock connectors both personally, and I ordered them for all my positions in the Army as I have found them to be the best connectors. Secure and removable for testing. Never had one fail, from automotive to marine applications.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is online now   Reply With Quote
Old 12-27-2019, 09:04 PM   #3
2007 22' International CCD
The Powerpole connectors are used all over with Ham radio gear and systems.
Standardized hermaphroditic connections that are easy to install, sturdy, and reliable. Using a crimp tool intended for them is key. Do not solder them,it does not make them work better.
The only thing I do special is use the little connector retainer clips on stuff that is rarely disconnected and subject to vibration.
All my radio and power supply gear uses them. Highly recommended! Just confirm to the standard polarity on paired connectors. Any vendor will have the data on that.
rmkrum is online now   Reply With Quote
Old 12-28-2019, 09:27 AM   #4
turk123's Avatar
2019 30' Classic
Canfield , Ohio
One note: Some of the China-made connectors you find on Amazon will not fit properly with actual Powerpole connectors. I bought a bag for a solar project for my Goal Zero and the connectors did not fit. Sent them back.
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Link to our shared album: https://photos.app.goo.gl/wACfGg1KcroVLP5m6
turk123 is offline   Reply With Quote
Old 01-06-2020, 11:47 AM   #5
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Thumbs up
I had to google it to see what those looked like... thank you for the suggestion John!
https://www.andersonpower.com/shop/w...powerpole.html
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 01-06-2020, 11:52 AM   #6
wachuko's Avatar
Orlando , Florida
Was this the crimping tool you got?
https://www.amazon.com/TC-1-Ratcheti.../dp/B00F1OUD5W
I recently got a similar crimping tool for the older wire connectors... got tired of the outdated and hard to use crimper that I had... Got this and it has worked great for those...
Safe travels!
Wachuko
WBCCI #26769
Old 01-06-2020, 01:01 PM   #7
Contributing Member
Pahaska's Avatar
Yes. Very nice crimper. Very hard to make a bad crimp with this one. When it clicks, the crimp is perfect.
John W. Irwin
WBCCI #9632
Old 01-06-2020, 03:16 PM   #8
2004 28' Classic
Roebling , New Jersey
As mentioned Anderson Power poles are used extensively in the HAM radio commmunity because of reliability and for standardization.
For a quality supplier IMHO I would suggest -
Powerwerx https://powerwerx.com/ provides the best support and genuine Anderson products / tools.
Dad250 is offline   Reply With Quote
Inside Cable Wire Connectors for TV Dgregfarmer General Interior Topics 12 12-30-2019 08:15 AM
3 way connectors for 8 gauge 12V wire? Airwave503 Electrical - Systems, Generators, Batteries & Solar 23 01-09-2015 07:51 AM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
Neat Puter fixer upper 53flyingcloud Off Topic Forum 6 04-10-2003 11:29 AM
Neat CB Holder Pahaska Our Community 12 11-19-2002 08:35 PM
