Old 05-13-2020, 10:55 AM   #1
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Mouse vs Sprinter
Several years ago, I had a check engine light on my 2015 Lounge. It turned out to be an air cleaner stuffed with a mouse nest. Mercedes at Georgetown removed the nest and put hardware cloth over the air inlet at the cost of several hundred dollars.
I have been dragging my feet, thinking I should mouse-proof the 2018 GT in the same way and always finding something else to do.
This morning, I started my 2018 GT and was greeted by a graphic on the display informing me that I had a dirty air cleaner. I opened the air cleaner box to find two-hands full of weeds. There is only 6800 miles on the rig and the air cleaner, itself, was almost clean as new.
I still have the "dirty air cleaner message." I'm not sure whether it will reset after driving or whether I need to take my OBD reader out to storage and try to reset it that way. I have a call into Mercedes Georgetown to see if they can give me some advice.
It is nice that the 2017 chassis has this display instead of just lighting the check-engine indicator.
I have some hardware cloth. I'll pull the grille tomorrow and mouse-proof the intake.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 05-14-2020, 09:10 AM   #2
Contributing Member
Pahaska's Avatar
Mouse proofed
I didn't find the hardware cloth that I thought I had, but I found a sheet of expanded metal that I like even better.
I went out to storage early this morning to mouse-proof the air cleaner. It probably took 10 minutes to remove the grille ... 4 push pins, 2 Torq screws, and depress 4 latches.
The expanded metal cut easily with a tin shear. The width of the metal was perfect. I had to cut one notch in the aft end to accommodate a rib in the plastic by the air box. I Held the metal in place and marked it with a Sharpie pen. From there, it was just cut along the line, drill 4 small holes in the plastic, and mount the metal with 4 screws.
These photos were taken before I temporarily removed the grid to spray it black.
ID:	367871   Click image for larger version
John W. Irwin
WBCCI #9632
Old 05-14-2020, 01:32 PM   #3
dznf0g's Avatar
Oswego , Illinois
Speaking as a retired auto industry professional, I am concerned with your fix. As a general rule, oem air intake systems are none too free flowing as is. You have reduced intake area by some 30 to 50%, just by looking.
-Rich-
Old 05-14-2020, 01:40 PM   #4
Contributing Member
Pahaska's Avatar
I think it is much less reduction than that. Just about the same reduction that Mercedes shop made on my 2015 Sprinter using a wire mesh. The intake is in a high-pressure area with RAM air through the grille and the turbo is pulling air. There is a LOT more resistance through the air cleaner element itself.
John W. Irwin
WBCCI #9632
Old 05-14-2020, 01:47 PM   #5
dznf0g's Avatar
Oswego , Illinois
Ok, it's up to you, but I anticipate low power under high load situations and false premature 'air cleaner" messages and maybe map/baro codes thrown.
There is a reason why the furnace bug screens are dome shaped. That's what you need to do here....and go back to a thin wired vs relatively large opening hardware cloth.
Not familiar with the space you have there, but a wire "box" would be easy to make.
-Rich-
Old 05-14-2020, 01:49 PM   #6
dznf0g's Avatar
Oswego , Illinois
You do understand that, turbo or not, the system is always comparing barometric pressure with software anticipated vs actual manifold pressure?
-Rich-
Old 05-14-2020, 04:11 PM   #7
Contributing Member
Pahaska's Avatar
The area I covered is substantially larger than the following ductwork. The resulting area is not even close to being the smallest place in the duct.
John W. Irwin
WBCCI #9632
Old 05-14-2020, 04:26 PM   #8
dznf0g's Avatar
Oswego , Illinois
Ok, you know MB layout specifics better than I do. Every mfr and model is somewhat unique. Just trying to help prevent any unusual events for you.
-Rich-
Old 05-14-2020, 04:54 PM   #9
van guru
1994 28' Excella
Hood River , Oregon
I would agree with dznf0g. The mesh itself creates turbulence which reduces air flow significantly. We did extensive air flow studies on this while I was design engineer at CASE. It's not only about the total open area. Even so mice can squeeze through incredibly small openings. Ask our cat.
All the best,
Hein
DIYvan
P.S. Want to know the easiest way to extract a mouse from under or behind the furniture? Shop vac!
Hein is offline   Reply With Quote
Old 05-22-2020, 10:28 PM   #10
2015 Interstate Ext. Coach
Lake Mary , Florida
John, no worries, there will be enough air in cylinders with your installed task. The combustible mixture in your Mercedes engine is designed with extra air margin, will be sufficient, and will not damage it neither affect your power characteristics. You have done a good job.
Mr. B is offline   Reply With Quote
Old 05-24-2020, 07:45 AM   #11
2013 Interstate Coach
Raymond , Iowa
I have a hard time imagining that a hardware cloth mesh of 3/8" or larger grid would reduce air flow. But if it is a concern you could install the grid over the air inlet only during periods of long activity (winter storage).
Titus is offline   Reply With Quote
Old 05-24-2020, 10:38 AM   #12
ScottP's Avatar
2019 27' Globetrotter
2019 Interstate Lounge Ext
Rye , New Hampshire
Irish Spring?
Deterrent:
What about some bars of Irish Spring soap sliced or shaved with a cheese grater and distributed under the drop line of your coach...maybe a few extra under your engine bay?
Recognizing mice also love to eat wiring...
ScottP is online now   Reply With Quote
Huge potential mouse entry on all Airstreams wacnstac Steps 15 02-14-2017 08:44 AM
2016 Sprinter questions from Sprinter newby Bobsprinter Sprinter and B-van Forum 7 08-28-2015 07:23 PM
Site for Sprinter & Sprinter-based RV Enthusiasts Zach Woods Sprinter and B-van Forum 0 09-25-2006 04:08 AM
Mouse problems 88Excella General Repair Forum 28 09-13-2005 09:19 PM
mouse mdlay General Repair Forum 13 02-28-2004 01:08 PM
