It’s mounted on the longest back panel directly under the backrest on your lounge. Open your back doors and it’s directly in front of you. If you have the pull out aluminum rest that the side bolsters rest on, that panel is basically right under that and as I said, the Magnum is mounted on the back side of the panel. You’ll probably have to take the carpet off the panels and if I remember right the screws can be seen to pull that panel off. If you do it, there cables and such attached to the inverter so don’t pull it off too fast or far. You can only tilt it down toward you if I remember correctly.
