Old 10-26-2020, 08:16 AM   #1
2014 Interstate Ext. Coach
Houston , Texas
Magnum Inverter easier 2014 Interstate 3500
Where is the actual inverter located in the early 2014 Airstream Interstate 3500 ext?
Tidoyle is offline   Reply With Quote
Old 10-26-2020, 10:32 AM   #2
Hawk-ination's Avatar
2014 19' International
Cedar Rapids , Iowa
It’s mounted on the longest back panel directly under the backrest on your lounge. Open your back doors and it’s directly in front of you. If you have the pull out aluminum rest that the side bolsters rest on, that panel is basically right under that and as I said, the Magnum is mounted on the back side of the panel. You’ll probably have to take the carpet off the panels and if I remember right the screws can be seen to pull that panel off. If you do it, there cables and such attached to the inverter so don’t pull it off too fast or far. You can only tilt it down toward you if I remember correctly.
Hawk-ination is offline   Reply With Quote
Upgrading from Tripplite to Magnum inverter/charger russ240 Sprinter and B-van Forum 12 04-27-2018 10:54 PM
2014.5 AI Magnum inverter not working in 12v... Air99 Sprinter and B-van Forum 6 07-07-2017 05:40 PM
Magnum inverter on 2014.5 AI- bad batts?? Help e93pvaz Sprinter and B-van Forum 6 09-05-2016 01:36 PM
prices of Magnum MS2812 2800W Inverter with 125 Amp Charger carl2591 Batteries, Univolts, Converters & Inverters 42 01-28-2014 03:26 AM
Magnum Energy inverter - chargers Jammer Batteries, Univolts, Converters & Inverters 5 03-22-2011 10:11 PM
