Old 10-12-2020, 05:11 PM   #21
2013 Interstate Coach
Kerman , California
2013 AI - where exactly is the fuse to change it?
I hear no sound when flipping on the pump. I have been reading different potential issues. I think there may be hair, or it got blown while I tried to empty the tank. >> where exactly is the fuse to change it?
PDX2662 is offline   Reply With Quote
Old 10-12-2020, 05:23 PM   #22
Indianola , Iowa
Fuse location is down below the rear lounge in the flip down fuse and breaker panel. If the fuse is blown, there should be a red light next to the blown fuse. Should be a 20 amp fuse.
nateallen80 is offline   Reply With Quote
Old 10-13-2020, 07:21 AM   #23
Proud Owner Vintage SBB
'55 Airlight's Avatar
Santa Monica , California
Images: 105
Macerator pump, blown fuses remedy.
Originally Posted by amirm View Post
Mine has blown twice in two years. I keep spares for that reason. I think it is a poor design. It should have a DC breaker, not a fuse. The initial surge depending on how stuck the pump is, causes the fuse to blow.
This is the correct diagnosis for the macerator pump fuse blowing. Consider that a simple remedy may be to install a relay in the circuit from the switch. That way you won't blow the fuse (from overload) when the pump starts grinding and pumping the contents of your blackwater tank.
"Of the gladdest moments in human life, methinks, is the departure upon a distant journey into unknown lands... A journey, in fact, appeals to Imagination, to Memory, to Hope,the three sister Graces of our moral being.
Sir Richard Francis Burton
'55 Airlight is offline   Reply With Quote
Old 10-13-2020, 09:44 AM   #24
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Replace the original fast-blow 20a fuse with a slow-blow 20a fuse. If you don't instantly hear the macerator start up, get your finger off the switch. The slow-blow fuse gives you a second or two to react.
I have never had trouble with the slow-blow fuse in two Interstates over time.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 10-17-2020, 05:39 PM   #25
2011 Interstate Coach
Evansville , Indiana
Pahaska
I’m trying to find the 20amp Slo Blo fuses on the net and am not having any luck. I’ve found the Large Maxi ones but can’t find the ATC size. Can you tell me where you got yours?
BurntAsphalt is offline   Reply With Quote
Old 10-18-2020, 11:17 AM   #26
Contributing Member
Pahaska's Avatar
Originally Posted by BurntAsphalt View Post
Pahaska
Im trying to find the 20amp Slo Blo fuses on the net and am not having any luck. Ive found the Large Maxi ones but cant find the ATC size. Can you tell me where you got yours?
I bought the slow-blow fuses for my 2014 AI about 4 years ago and I have no idea where I found them. I located them with a Google search and that's all I remember. I had to buy 10 of them.
John W. Irwin
WBCCI #9632
Old 10-18-2020, 02:11 PM   #27
St George , Utah
There are circuit breakers that can be plugged into the fuse board in place of a fuse -- for example:
https://www.amazon.com/Tocas-Manual-...051769&sr=8-15
There are also Maxi fuse to ATC fuse adapters, and slow blow Maxi fuses are readily available.
AtlasKen is offline   Reply With Quote
AC, Microwave, Elec Hot Water Heater, TV = Blown Fuse KJRitchie Electrical - Systems, Generators, Batteries & Solar 36 09-10-2013 12:57 AM
Blown negative fuse Bigjohn59 Batteries, Univolts, Converters & Inverters 0 08-13-2013 09:50 PM
No power blown fuse Gosman Lights - Interior & Exterior 7 10-06-2010 07:46 AM
Blown fuse toastie Batteries, Univolts, Converters & Inverters 7 09-05-2007 07:07 PM
Marker lights blown fuse Paul Daugherty Classic Motorhomes 0 09-07-2005 08:28 PM
