Old 10-25-2019, 12:12 PM   #1
2014 Interstate Ext. Coach
fairfax station , va
Macerator hose reel
I have several issues with my macerator.
One is that the leader hose from the pump to the hose reel seems to leak.
Can anyone confirm for me that this is the OEM hose reel, before I go any further into the disassembly DIY void?
2014 EXT
https://www.dyersonline.com/shorelin...hose-reel.html
VAtom is offline   Reply With Quote
Old 10-25-2019, 03:04 PM   #2
2013 Interstate Coach
Raymond , Iowa
Same concept but definitely not the same hardware as on my 2013 Interstate EXT. If I recall correctly the ID of the short section of hose leading from the macerator to the hose reel is different than the ID of the hose on the reel. I replaced the reel hose but not the inlet hose. Was able to remove the hose reel working from the side of the van. Biggest problem was removing the hose from the nipple on the hose reel. Had to slice up the side of the hose to slip it off.
Titus is offline   Reply With Quote
Old 10-25-2019, 04:11 PM   #3
I think you are right. The hose reel hose is 1" OD (prob. 3/4" ID) and the pump barb is 1" OD meaning the leader hose OD is significantly more than 1"
Thanks for your opinion on the reel. The Airstream parts manual is silent on the matter.
Old 10-28-2019, 11:54 AM   #4
AI Joe's Avatar
Key Largo , Florida
Images: 11
Perhaps this?
https://smile.amazon.com/dp/B004OZR2...v_ov_lig_dp_it
AI Joe
Remember: "it's even better in an Interstate!"
AI Joe is offline   Reply With Quote
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 38 09-23-2020 10:41 AM
Macerator Hose Reel DayStreaming Sprinter and B-van Forum 5 03-20-2017 02:44 PM
Macerator Pump hose Reel Blowing fuses WBS248 Waste Systems, Tanks & Totes 2 11-25-2016 11:18 PM
Is there a way to manually retract the macerator pump hose if the reel motor stops wo Jimcyn Airstream Motorhome Forums 4 10-25-2014 07:07 PM
Fred vs. Hose Reel ViewRVs Airstream Motorhome Forums 10 09-01-2007 07:34 PM
