Old 08-31-2018, 07:48 AM   #1
RC-AV8R's Avatar
Salem , New Hampshire
Loose Sliding Door Seal on Chassis
Just a FYI for others that may experience the same problem. After setting up camp yesterday, while opening the sliding door, something long fell off the vehicle and onto my head on its way to terra firma. It was also slightly bent, likely the last time the door was closed. It turned out to be the dust/water seal attached to the sprinter sliding door opening on top. It seemed to be mainly secured with friction, although there are traces of caulk in the track. I was able to straighten it out with some tools and reinstall it, but I'll have to get another from the factory since I trust it much less now. Your milage may vary, but it's worth taking a look to see if yours is still firmly seated to the body if you have an older AS model.
With a 2 year old AS, I clearly didn't expect this.
All that is gold does not glitter,
Not all those who wander are lost
RC-AV8R is offline   Reply With Quote
Loose Rubber Seal in Storage Compartment PatLee General Repair Forum 12 08-25-2018 06:33 PM
Sliding screen door for the sliding door! weirdstuff Sprinter and B-van Forum 29 02-28-2014 08:19 PM
To 'seal' or not to 'seal'?? b8sfamily Floor Finishes 6 03-31-2009 06:13 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
