Hi all,
First time posting, but have been reading for a few months before I decided to buy an interstate.
I’m wanting to install a Victron BMV 712, and I’m not sure where the current ground buss is located for a 2019 Interstate Lounge Ext Slate.
I’ve got 4 lithium batteries located under the coach, which I believe was the location of the original AGM batteries, and I see the negative go back into the coach, but have no idea where it goes.
So in short, I’m willing to pull some things out to find it, I would imagine it’s under the road side jump seat, but want to make sure I’m not going the wrong way. I’ve found CBL8, but can’t find CBL4. My
12v schematic is going to be a bit different, but should be same general area.
I gather I need to put the shunt and have the batt connect directly to neg on Batt and the load will goto the ground buss.(I’m just guessing)
Anyway, if you know where that Batt negative cable (CBL4) goes to and terminates, I’d be grateful for a pointer.
Cheers,
Pucky
