Old 04-29-2025, 08:55 PM   #1
2023 Interstate 19
Hurricane , Utah
Location of fuse MF2 on Interstate 19
Need help locating the fuse “MF2 “ on a 2022 Airstream Interstate 19. The wiring diagram shows it is a 50 amp stud mount fuse located between the DC to DC converter and the Coach Batteries. It is not located in the fuse panel located under the reclining sofa which is accessible from the D/S rear door. Please help. Thanks.
Interstate 1 is offline   Reply With Quote
Old 04-30-2025, 02:00 PM   #2
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
That fuse is a stand alone item and would not be in the fuse panel. Did you look at the curb side battery terminal it could be mounted right on the battery?
I don't have an Interstate with your configuration, but the 2022 AI-19 parts book lists a fuse that matches the part number on the 2022 wiring diagram (512660-50 Terminal fuse, 50 amp, Red). That tells me the fuse is likely mounted right on the battery. Images of the fuse and holder attached below.
ID:	452779   Click image for larger version
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 05-01-2025, 01:18 AM   #3
2023 Interstate 19
Hurricane , Utah
Thanks! You helped me find itI. It is located on the positive terminal on the “Roadside” battery. Thanks !!
Fuse remover, fuse set, light Vitaver Electrical - Systems, Generators, Batteries & Solar 6 09-21-2024 10:58 AM
Blown fuse indicator stays on with new fuse Bluetick Batteries, Univolts, Converters & Inverters 0 06-20-2024 03:48 PM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
Interstate DVD fuse location rving42 Sprinter and B-van Forum 2 03-11-2007 09:32 AM
