Old 05-08-2020, 01:08 PM   #1
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Levelling Block Fix
I bought 12 heavy-duty levelling blocks for the Interstate. I had a lot of the "Lego" orange blocks left over from the trailer, but I found that the higher weight of the Interstate will break them if the surface underneath is rocky or uneven. The heavier blocks are a lot stronger.
Unfortunately, the heavy blocks do not do well when stacked higher than one level. The usual 2 on the ground and one centered on top do not lock together like the Legos. The top block just slides off the stack.
I decided to drill 4 holes in each block and cut some pins to lock the blocks together. I had some 3/8" steel rod, so I made a plywood jig and drilled 48 holes, 4 in each of my 12 blocks. The holes are drilled a bit oversize so that the pins insert easily. The drilling got a bit old after a while.
I cut lengths of 3/8" steel bar and chamfered the ends using my grinder. The first test was successful. I can also use 3/8" bolts as pins.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Pahaska is online now   Reply With Quote
Replacement levelling valve for 1981 Excella 28 motorhome Georgie Mechanics Corner - Engines, Transmission & More... 5 04-27-2016 11:03 AM
Conquering GM's Auto Levelling System Pat Cassity Tow Vehicles 16 02-13-2015 11:42 AM
Air levelling valves and Shocks shepherd57 Classic Motorhomes 4 04-10-2013 06:34 PM
Spring Bars too tight? And Automatic Levelling Suspension Question lbrownah Hitches, Couplers & Balls 5 04-30-2010 05:22 PM
Land Yacht Air Levelling Mod porourke Jacks, Stabilizers, Lifting and Leveling 1 07-05-2009 10:21 AM
