Old 08-21-2020, 06:50 PM   #1
2012 Interstate Coach
Point Clear , Alabama
Key doesnít turn ignition
Today I went to the barn where I keep my AI 2012 45000 mi
And my clicker (key fob) didnít work. So my year model the key has a button you press and the blade of the key swings out to unlock the door but
The key would not turn in the ignition. Steering wheel wouldnít budge. Everything in the coach working but plugged into Shore Power.
Any guesses ?.... tomorrow I am going back over there with my voltmeter but thought someone may have a tip for where to look.
Boosa is offline   Reply With Quote
Old 08-21-2020, 07:26 PM   #2
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Bad battery in the key fob. Key will not turn in ignition without a good battery in the fob.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 08-21-2020, 09:28 PM   #3
Iíll check it out thanks
Old 08-22-2020, 12:50 AM   #4
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Yipes, you can be stuck somewhere because a battery died in a key fob?
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 08-22-2020, 01:04 AM   #5
Long Island , New York
Does the Mercedes owner's manual cover this, John? Difficult to imagine that they would intentionally put such a weak link into the middle of an otherwise strong chain IMO.
Any chance it's just a mechanical issue with the ignition interlock at the steering wheel?
In our Ford van, and in earlier model years as well, sometimes we have to wiggle the steering wheel a bit, so that the key can turn freely in the ignition.
If there is a second key fob nearby, with a healthy battery, is this enough to let the ignition proceed, with the first "dead battery" fob turning the ignition? Restated -- so the old days of just a mechanical key being enough are long gone?
Thank you John for further clarification from your deep Interstate knowledge base.
FWIW
Peter
Let the music lift you up . . .
OTRA15 is online now   Reply With Quote
Old 08-22-2020, 06:20 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Possible mechanical problem....steering wheel is locked, move it back and forth to relieve any tension as you try to turn the key.
It's always best to remove the key with the wheel straight ahead when possible
Obrigado, ť hora de descansar.
Tahawus
Old 08-22-2020, 10:42 AM   #7
DR M
2011 34' Classic
Eastlake , Colorado
Maybe there's a safety feature that if the coach is plugged into shore power you can't start the coach.
2011 34' Limited Classic
2017 F350 King Ranch 4x4
DR M is offline   Reply With Quote
Old 08-22-2020, 11:57 AM   #8
Camarillo , California
Is unit in full park position?
Be sure shift lever is in park.
1jacobo is offline   Reply With Quote
Old 08-22-2020, 03:07 PM   #9
1988 32' Excella
Robbinsville , New Jersey
Check chassis battery?
House batteries may be only ones charged.
Old 08-22-2020, 10:53 PM   #10
van guru
1994 28' Excella
Hood River , Oregon
This has happened to us and can be caused by a dead chassis battery. Best to unhook the negative by the accelerator pedal during extended storage.
All the best,
Hein at DIYvan
Hein is offline   Reply With Quote
Old 08-23-2020, 08:27 AM   #11
I had to make Tropical Storm preparations yesterday but came to check out my problem today.
My chassis battery is dead. Thanks for everyone’s input. I knew you guys would point me in the right direction!
My question now is looking at the control board or whatever you call it. Located in the rear cabinet. It shows main battery 13.68. Batt Aux 14.20. I’m plugged into Shore Power. ??
Does this indicate my House Batteries are dead? And how about the Battery Separator? I have a 2012 AI rear lounge. So to get to the House Batteries to check I need to remove the rear seat,correct?
Old 08-23-2020, 01:15 PM   #12
van guru
1994 28' Excella
Hood River , Oregon
Those voltages indicate that there are charging sources active. You'll want to unplug from the shore power, remove all loads, let the batteries rest for a time and then take another look at the voltages. A fully charged lead/acid battery should be at ~12.6 VDC.
All the best,
Hein
DIYvan
Old 08-23-2020, 04:37 PM   #13
2013 Interstate Coach
Raymond , Iowa
On my 2013 lounge the batteries can be reached from the back. Remove a metal plate at the back of the battery box - curb side, carpet velcroed to it. But your 2012 may be different. But I do have to remove the seat to get to the BIM.
You shouldn't need to remove them to check them. Just use the same rocker switch as before, after the waiting period suggested by Hein.
Titus is offline   Reply With Quote
Old 08-24-2020, 12:29 PM   #14
When I unplug from Shore Power everything is dead. The Control Panel (in the cabinet above the rear lounge) is completely dead. Nothing lights up. I guess my next step is remove the rear seat to gain access to the House Batteries unless there is a test point with easier access.
My AI is a 2012 I saw details on how to remove seat so I’ll check back. But this will take awhile I’m sure.
Old 08-24-2020, 02:57 PM   #15
Indianola , Iowa
There’s a main 200 amp fuse between your batteries and your positive bus bar that may have blown.
nateallen80 is offline   Reply With Quote
Old 08-25-2020, 10:12 AM   #16
Is there a wiring diagram for a 2012 AIRSTREAM INTERSTATE. That would be so helpful.
Old 08-25-2020, 05:29 PM   #17
Boxster1971's Avatar
Fulton , Maryland
You might try contacting Airstream and ask for a set of wiring diagrams for your 2012 Interstate. That is how I got a partial set for my 2013. Since they now include wiring diagrams in the owners manuals since about 2015 they are more willing to give owners the wiring diagrams.
If you Send me a private message on this forum with your email Iíll send you the wiring diagrams I have.
- - Mike
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Lost ignition key, best solution? SteelyDan Classic Motorhomes 8 10-24-2012 07:21 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
diesel engine doesn't turn off with key hit the road Mechanics Corner - Engines, Transmission & More... 13 02-08-2010 06:12 PM
Key Stuck In Ignition doorgunner Mechanics Corner - Engines, Transmission & More... 26 11-12-2006 07:17 PM
