10-23-2020, 09:47 AM
The Gadget Guru
Airstream - Other
2021 Interstate 24GT
Golden Oak
Is This Acceptable Roof Work?
I hope you don't mind me asking this question, but I was a bit taken back when I climbed on a ladder to view my the roof of my new 2021 Interstate GT.
Please note, I came from the Prevost world and while an Interstate costs around 10% of the price of a new bus conversion, I was a bit dismayed when I saw the installation of the satellite dish on the roof. So, I thought I would ask your opinion whether or not this is acceptable or if it may be deemed sloppy or rushed by the dealer.
As stated, I'm comparing this to a bus that cost quite a bit more, but the roof on the big bus was much neater. I welcome your responses.
10-23-2020, 09:52 AM
2012 25' FB International
Trent Woods
, North Carolina
You already know the answer. There is no excuse for the lack of workmanship whether done by the local garage mechanic, a dealer, or even yourself. Problem is, whoever tolerated that level of hack workmanship cannot be trusted to carefully undo it and do it right.
Larry
10-23-2020, 12:07 PM
Prof. of Pending Projects
2018 Tommy Bahama Interstate
Orlando
Bought mine new as well (2018)... Right after I got mine I went over everything on the roof...
I got some Sikaflex 221 and redid all seals (since it was new I did not removed the one there). Placing tape and applying additional Sikaflex to make it look properly finished....
My concern with your photo is that I can't understand why that blob of sikaflex is there??? Did they incorrectly drilled the location of the satellite dish??
10-23-2020, 12:27 PM
2014 Interstate Ext. Coach
Boca Raton
Looks like a mess of Disitin around that
10-23-2020, 06:11 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard 👍
Cheese & crackers got all muddy....You went on the roof?
Only birds and angels are allowed to see the roof.
No..THAT is unacceptable I would also demand it be re-done correctly, and explain the blob.
Return to the dealer, ask to see the Dealer Principal and show it to him or the Service Manager, I'll wager neither signed off on it, if they did, find another shop.
Call JC and send pictures.
The solar install is not anything to write home about...JC maybe.
"You don't know where you've been until you leave, enjoy life" RLC
10-23-2020, 06:32 PM
2019 22' Sport
Port Coquitlam
, British Columbia
Congrats on the new Airstream GadgetGuru
On a positive note, they used the entire tube or case of tubes! It looks like you got all the Sikaflex that the shop had in their stores. What do you think is under the blob? Is there a large hole?
Perhaps the tech is taking a cake decorating course and this is a masterpiece.
But all kidding aside, give JC a call and send some photos and get this straightened out to your satisfaction. They will never know about it unless you tell them.
Like Bob says, the solar install looks weak. Maybe JC should be questioned about this as well.
Peter.
"Live Long and Prosper \\//" - Spock
10-23-2020, 07:14 PM
Normal
I’m with wachuko...what the hell is under that big blob of caulk?
Our first Interstate was like this...looked like the caulk around every add-on had been put down by a toddler with a wooden spoon, and there were all sorts of issues covered with that caulk that eventually leaked.
Maggie
10-23-2020, 07:20 PM
2019 30' International
Pennsylvania
, Pennsylvania
That's messy. It almost looks like the edge of a round plate under that blob. I'd call foul and explore the issue, surely desiring to know what's under there.
For me, it's always off to the factory for warranty work. That may be quite a drive for you, but I recommend it if you have the time and resources to do so.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
10-23-2020, 07:30 PM
2019 19' Flying Cloud
Canyon Country
I am shocked when I saw that theres a flexible solar panel... it is known for causing heat damage on roof.
Yes the sealant work is very shoddy...
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
10-24-2020, 08:50 AM
2024 Interstate 19
Fulton
, Maryland
That is typical sloppy work from Airstream. You will see a lot of it if you look behind the surfaces of the van. Airstream trades on their designs and finishes, not the quality of their builds. To get Prevost quality in a B-van you need to buy from Advanced RV.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
10-24-2020, 12:03 PM
2016 27' Flying Cloud
McDonough
, Georgia
Hard to tell, but it also looks like the satellite dish base is blocking part of the solar panel.
P.S. If I had to guess, I'd say they drilled the first hole for the dish too close to the solar - if that dish were centered over the caulking blob it would have blocked a lot of the solar. (Just my 2cents, discounted by $.02)
10-24-2020, 12:38 PM
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista
I visited the factory and they have caulking in 55 gallon drums with pumps and hoses , they just pour it on, the trigger must of stuck.
10-24-2020, 01:36 PM
1997 25' Safari
Laurel
, Maryland
? Not just NO but H**L NO!
I have done some sloppy work, this is well beyond my capabilities of sloppy!
As others have posted, this tech can NOT be trusted to fix it.
Solution? Unfortunately I don’t have any. Good luck. Rick
10-24-2020, 02:03 PM
2019 20' Flying Cloud
Eau Claire
, Wisconsin
Sloppy all the way
Can’t figure out what they did or didn’t do around the dome but the solar panels should be on some sort of standoffs. Not screwed to the rounded roof. I’m guessing that their will be trouble ahead in the near future if it’s not taken care of. Back to the dealer and ask questions of how and why. If not acceptable answers then talk to JC. Good luck. Joe
10-24-2020, 02:13 PM
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas
, USA
Not that you need another opinion but I'll join the chorus. That is unacceptable and as already pointed out "what, if any, issue is that glob hiding?".
I would call Jackson Center and get them involved ASAP.
10-24-2020, 03:44 PM
2002 19' Bambi
Lafayette
Well, perhaps Airstream does not know about future trouble, but that is presently their standard solar panel installation on the Interstate. The attached picture is from the Airstream website.
Tim
10-24-2020, 06:01 PM
Silver Star
1970 23' Safari
Victoria
, British Columbia
It looks like they installed the sat dish then realized the solars panels wouldn't fit and moved it.... and then were totally hoping you wouldn't look up there!!! Time to raise a little hell !!
10-24-2020, 06:09 PM
1995 25' Excella
xxxxx
, xxxxxx
Its probably hiding roof damage
10-24-2020, 07:23 PM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Definitely not acceptable. What a mess.
10-26-2020, 06:27 PM
Airstream Ambassador
Jackson Center
, Ohio
Hi GadgetGuru,*
Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can learn more and share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
