Old 11-01-2017, 08:58 AM   #1
Harrisville , Michigan
Inverter question, 2016 grand tour.
We are heading out to Florida for the winter and taking the airstream. I usually park it in a storage area at our condo that is uncovered. I am wondering if I need to leave the inverter on when storing so the solar will trickle charge the house batteries. I do turn off all the power and unplug things that may get a parasitic drain.
Or......would I be better off turning off the main disconnect to the house batteries and then turn off the inverter. On all my other coaches I had to leave on the inverter to get the house batteries to charge from the solar.
thanks,
jtmac is offline   Reply With Quote
Old 11-01-2017, 09:27 AM   #2
2017 Interstate Grand Tour Ext
Houston , Texas
Always turn the Inverter off. It plays no role in charging the batteries, and only draws current. Also make sure you turn the outside LPG switch off, it has a significant parasitic drain.
Leigh & Bettie
Houston TX
2017 Interstate GT
BMW R1200GS
TayaraTravel is offline   Reply With Quote
Old 11-01-2017, 09:34 AM   #3
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
The inverter will be disconnected when you switch the main disconnect switch to off. There is a second motor-powered rotary switch or a solenoid that disconnects the inverter in all recent AI.
In my 2014.5, it was a stupidly-engineered solenoid that I replaced with a manual switch.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 08-15-2020, 05:11 PM   #4
2017 16' Sport
Traverse City , Michigan
Trying to understand all the different threads on how to “disconnect/turn off” my inverter.
I have a 2016 Grand Tour Ext and I am pretty sure I do not have the Airstream solenoid. I have removed the BIM and battery isolator, choosing to wire the alternator side directly to a dc to dc charger and the lead from the inverter fuse to isolator to the house batteries.
Should I put a battery disconnect switch on the wire from the inverter fuse to house batteries to stop the parasitic battery drain?
I am attaching a picture of my inverter area prior to my modifications.
Heckler56 is offline   Reply With Quote
Old 08-15-2020, 07:43 PM   #5
2013 Interstate Coach
Indianola , Iowa
If you really want to stop the parasitic draws, put a switch between the battery positive and the 200 amp main fuse.
nateallen80 is offline   Reply With Quote
Old 08-16-2020, 06:34 PM   #6
2017 16' Sport
It would be nice while boondocking to not have the inverter draining additional power.
In all fairness, I have been avoiding hitting the master battery switch thinking my new Balmer shunt would not keep an accurate soc or soh. But duh, the shunt has a positive lead directly on the battery. Can’t believe I spent the last two weeks worrying about that...
Old 08-16-2020, 06:40 PM   #7
Indianola , Iowa
I put my victron battery monitor positive on the other side of the switch, as my coach sits in storage for months at a time.
2016 Interstate Grand Tour - Better solution for front night shades? Tao Sprinter and B-van Forum 25 10-01-2016 09:56 PM
2016 Grand Tour steering vibration Sgkh1947 Sprinter and B-van Forum 13 11-18-2015 07:53 PM
2016 Grand Tour battery problem Bobsprinter Sprinter and B-van Forum 12 08-13-2015 04:46 PM
Drivers seat - extended? 2016 Grand Tour Tao Sprinter and B-van Forum 17 07-04-2015 10:35 AM
