Old 09-16-2021, 01:24 PM   #1
2015 Interstate Ext. Coach
Sea ranch lakes , Florida
Inverter not powering up.
Inverter not powering up. 150a fuse good. House batteries good. Have power to a solenoid? Not on schematics. No power at other side of solenoid. No idea what triggers it. Help!
Dirkpitt is offline   Reply With Quote
Old 09-16-2021, 01:59 PM   #2
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
We need a year and model on queries such as this.
It sounds like the solenoid might be the recall "fix" Airstream had for about 2014 models. That solenoid is a piece of junk and fails often. The purpose was to turn off AC to the inverter when the disconnect switch at the door is turned off.
On my 2014.5, I replaced the solenoid with a heavy-duty manual battery switch. On later years, Airstream replaced it with a second motorized switch.
Old 09-16-2021, 02:03 PM   #3
2015 interstate lounge.
Old 09-16-2021, 02:33 PM   #4
What’s the trigger?
Old 09-17-2021, 09:45 AM   #5
RidingmyRV's Avatar
2015 28' International
Portsmouth , Virginia
What’s the trigger? I believe you want to know what powers up the inverter. If that is the case. On my 2015 international the inverter on off switch is located on the fresh water black water grey water indicator panel. I apologize in advance of this is not what you are asking.
RidingmyRV is offline   Reply With Quote
Old 09-17-2021, 09:52 AM   #6
Contributing Member
Pahaska's Avatar
The solenoid is controlled by the disconnect switch at the door. You should be able to meter the wires into the solenoid to see if the solenoid is getting power.
There is also the motorized red rotary switch by the fuse panel. That switch is also controlled by the disconnect switch at the door. That switch should be rotated to the clockwise position if the door disconnect switch is turned on.
Old 09-17-2021, 09:54 AM   #7
Contributing Member
Pahaska's Avatar
The question referred to an Interstate where the inverter situation is completely different from trailers.
Old 09-17-2021, 01:50 PM   #8
Awesome! You guys are better then a service manual. Now, million dollar question. How many amps is the solenoid?
Old 09-17-2021, 04:09 PM   #9
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
At least as much as the fuse that feeds it.
Old 09-17-2021, 04:42 PM   #10
Contributing Member
Pahaska's Avatar
Awesome! You guys are better than a service manual. Now, million-dollar question. How many amps is the solenoid?
Because the solenoid was a recall addition, it is not shown in the schematics in the user manual. I believe the power wires through the solenoid would be on 20 amp CG #4. The control wires for the solenoid would tie into the disconnect switch at the door.
Old 09-19-2021, 01:34 PM   #11
Solenoid was bad. Ran numbers on back. 200amp continuous duty, made in Mexico. Replaced with cole hearse 85amp continuous duty, all I had. 200amp CH later.
USB Receptacles not powering rajsingh Sprinter and B-van Forum 11 08-13-2018 08:28 PM
generator not powering A/C 02interstate Sprinter and B-van Forum 16 02-12-2018 03:37 PM
Battery not powering 12-volt system worksology Batteries, Univolts, Converters & Inverters 0 04-21-2012 09:00 PM
Powering my Sirius receiver. Toronto_Guy Audio, Video & TV 4 10-05-2009 07:49 PM
Control center not powering up gparker Electrical - Systems, Generators, Batteries & Solar 1 07-14-2006 07:13 PM
