Interstate Step Problem
We have a 2012 Interstate and our step quit working just like yours (motor running, no step open or close). We found NO dealer that knew how to fix it, rather just open it up and see what happened (and charge us). After that we took the assembly down from under the vehicle, opened the box top cover and found a set screw on the drive gear was loose allowing the motor to spin (motor running sound), but the drive gear was not engaging with the chain that opens/closes the step. After we tightened the set screw on the drive gear, the step works fine. Kind of a mess taking the assembly down and apart, but once you open the box, tighten the set screw, it bolts back easily and done.
Attached picture shows the open box, gear and set screw. The good news: you don't have anything broken, the bad news: you have to drop the box, open it, tighten the set screw and put it back.
