08-08-2019, 05:57 PM
#521
2018 Interstate Lounge Ext
LV
, Nevada
Originally Posted by Lily&Me
Just a reminder, particularly for those of us with older rigs...
Our propane hoses need to be replaced periodically, to avoid potentially disastrous leaks that can also occur at the most inopportune times.
A cautionary tale...be safe.
Maggie
Originally Posted by InterBlog
As a thread refresher, here is my replacement step-by-step. I had the four flex lines custom fabricated to the recommended spec, but we did the installation ourselves.
MAGGIE , INTERBLOG - Thanks You both. Good stuff. Did not know this stepxstep existed, it was before my join date. Glad you both re-surfaced this fix.
08-09-2019, 06:16 AM
#522
League City
May we reiterate as well that this just boggles my mind, that there is not an entire formal framework in place to alert owners to the need for this replacement (such as bulletins from Airstream or something similar) -- especially given that the hoses are *designed* with a finite lifespan, partially by virtue of their fail-safe pressure construction (per the manufacturer Parker).
How many times do we have to hear from owners who caught line failures before their rigs went up in a fireball? Someone is going to get injured or killed, and then the resulting civil suit will trigger a change in attitude and procedure. It's a shame that it has to come to litigation and damages, but that's the typical pattern.
08-09-2019, 06:25 PM
#523
LV
, Nevada
INTERBLOG - Do you think stainless steel braided hoses will help or would that just have disintegrated rubber hose under it? This is my 1st exposure (no pun intended) to constantly exposed propane lines, so no idea what would actually be the cause of the limited lifespan. I have only used portables that get stored
08-10-2019, 08:18 AM
#524
League City
I could not get any official traction on answering that exact type of question.
I, too, wanted to put more robust hoses on our van, but I was told by several vendors, including the authorized Parker representative who fabricated our new ones, that the hoses that were put on there to start with are a spec designed to be appropriate for that application, and to guard against overpressure explosions. The hoses are supposed to fail "gently" if accidentally subjected to excess pressure, rather than blowing someone's head off in the process.
Unfortunately that same built-in weakness is also what limits their lifespan.
OR SO I WAS TOLD. It's important to note that this information came to me by various word-of-mouth. I've got nothing official in writing to back any of it up at this point.
Bottom line: Because the application in the camper van context called for "explosion-proof" hoses, nobody was willing to touch my question about what my alternatives might have been. Too much liability in even discussing it.
So, as a result, I don't know what else in the way of hoses could possibly be used safely on these rigs. I went with the same Parker spec hoses as what had been placed on there by Airstream years before.
08-10-2019, 12:36 PM
#525
LV
, Nevada
INTERBLOG - Got it. That does make sense. I did browse Parker site and there doesn't appear to be anything with other external reinforcing materials , even those made for commercial use.
08-10-2019, 12:51 PM
#526
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
I bought MY interstate with a failed high pressure propane line. That was, I'm sure, part of the reason I got such a steal on it. It is, of course, replaced now. The low-pressure lines aren't AS big a risk as they can be shut down with the tank valve until they can be replaced. And, they seem to last much longer. When the high-pressure line between the fill valve and the tank goes, you lose 7 gallons of propane all at once. NOT a good place to be at all.
I ALSO had two propane appliance valves that were leaking; the water heater and the furnace, and the furnace was venting propane into the cabin. Thank God for propane sensors.
Anyway, the propane system in mine is up to snuff again now... almost $1500 later and three trips to US Adventure RV in Davenport.
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
08-10-2019, 01:02 PM
#527
LV
, Nevada
85MH325 -You must be living right, coz you very lucky to catch it. I was even thinking of a redundant propane sensor before my stuff gets too old & be able to sleep better.
08-11-2019, 05:17 AM
#528
League City
I hope the rest of y'all are in nota bene mode here. In other words, I hope you are taking this issue seriously. It's not if these lines are going to fail - it's when, if they are left in place for a sufficiently long interval of time. Which equates to plus-or-minus right about now, if you are a T1N Interstate owner. There's certainly enough evidence to support that conclusion. That evidence is anecdotal, but it's strong and consistent.
I have a pet peeve with senseless injuries and premature deaths from all causes. Not only does this make no sense in the context of the self, it places a tremendous burden on loved ones and society. If we take every reasonable precaution not to make burdens of ourselves and something bad happens, well, that's just life and we cannot be blamed. But if we ignore or deny risks and then end up dead or injured, that is the ultimate affront to the entire world. There's no integrity in it.
I'm sitting about 10 feet from my almost-83-year-old father as I type this. He asked me a long time ago what I would most like from him, as a father. I said, "Just keep living well; everything else is secondary." He's eating his granola and pineapple. And then later today, he'll religiously do his exercise, and engage in the rest of his healthy lifestyle. That's what I wanted. Nothing else is important, really.
08-11-2019, 05:42 AM
#529
Sneedville
, Tennessee
What's the link to your blog on hose replacement? I found the tank article and another talking about someone else's hose issue but can't find yours. Lily and Me had to replace a hose recently after the high pressure hose split right after silling the tank.
08-11-2019, 05:47 AM
#530
Normal
One of the things I am still learning is the need to have specific systems...like the propane...examined, rather than trusting the mechanic underneath who you ask to “please take a good look at everything” to actually look at everything under there.
And then, of course, report to you anything that seems to need attention.
Tho I am highly claustrophobic, and do not get under vehicles , I am seriously thinking of getting under there myself just to see what I can see.
Or, get in the pit at the next service appointment, and look from there while everything is visually accessible.
Maggie
08-11-2019, 12:22 PM
#531
LV
, Nevada
TINCAMPERS - Post #520 or click her " here" above
08-11-2019, 12:57 PM
#532
Sneedville
, Tennessee
TINCAMPERS - Post #520 or click her "here" above
Thanks!
08-11-2019, 01:37 PM
#533
Contributing Member
Austin (Hays County)
Or, get in the pit at the next service appointment, and look from there while everything is visually accessible. Maggie
My local Mercedes shop, who I really like, invited me into the shop with my 2014.5 on the lift and gave me a tour of all the OEM parts under there. They gave me time to look at the tanks and propane systems.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
08-11-2019, 01:48 PM
#534
League City
I was claustrophobic from about September to December 2014. Then I acclimated myself to being under the Interstate. Ramps help tremendously.
There's nothing that makes itself apparent visually with the propane hoses. They appear to just fail spontaneously, without showing signs of wear.
08-11-2019, 03:17 PM
#535
Sneedville
, Tennessee
So, what kind of facility made up the new hoses? I’ve been looking but can’t anything local in Knoxville.
I have been suffering from claustrophobia for a number of years. Getting on an airplane was a real struggle. Even today laying on my back under the Interstate gives me pause. This has been going on since Y2K. It is slowly getting better.
08-11-2019, 05:59 PM
#536
Normal
I think you would need to get on the phone and call around, to find a place that could make these hoses.
Some shop that can construct a part, like the one the folks at home found when mine split.
They mentioned there were two places locally that used to make them, but no longer does because of liability.
Maggie
08-12-2019, 04:01 AM
#537
League City
Interstate Maintenance & Upkeep
Call Parker and they should be able to point you toward an authorized rep. Google Parker hose (it’s now called Parker Hannifin).
08-12-2019, 04:05 PM
#538
LV
, Nevada
I saw this searching websites for fabricators
https://gashosesandregulators.com/
"GasHosesandRegulators.com specializes in stocking and selling propane and natural gas hoses for most any application. We stock low pressure (natural gas and low pressure propane) gas hoses from 3/8"ID up through 2"ID in conventional strip wound AGA hose and also in stainless steel overbraid. We also stock a wide variety of high pressure and low pressure regulators of many variations."
Just perusing through their high pressure hoses, the prices of the stainless steel braided protected variety seems to be double of the standard. Pic show identical hoses, except The thermoplastic 10ft around $28 while the stainless steel overbraided version is $53. They in Houston, TX. I will ask them if these hoses can be stored indefintely or best to order if/when need arises..
08-12-2019, 04:21 PM
#539
Normal
I think my new hose was $144.
Maggie
08-12-2019, 05:03 PM
#540
2007 22' International CCD
Corona
Any product with vulcanized rubber has a lifetime that starts when it is made, not installed. Any polymer ages and breaks down gradually with time.
That’s why it’s good to make note of the manufacture date and replace rubber parts every 5-8 years, depending on what it is being used for.
