Old 05-20-2017, 11:38 AM   #61
Njg
Njg's Avatar
2018 25' International
Columbia , Missouri
I have to admit that the video on AM solar about the VHB is compelling. Tape and sikaflex it is... thanks all for your help!
Njg is offline   Reply With Quote
Old 05-21-2017, 08:59 AM   #62
Naples , Florida
Originally Posted by Njg View Post
Thanks for that information! My plan was to use the VHB tape but then screw through that and cover the whole base with dicor. How long were the screws you used?
Also, lew, if I am sticking with the Airstream supplied lifelines for now, what settings on the victron MPPT to you recommend? One of the canned settings or custom settings. I have the Bluetooth attachment so can readily change them.
I would suggest the Blue Solar 100/30 so you have the capacity for a potential of 400 watts. Also get the Blue Tooth Dongle so you can program and monitor the controller from your phone. The BMV=702 is also a superior battery monitor!
lewster
Old 05-21-2017, 09:11 AM   #63
Houston , Texas
Totally agree with Lew. Here is mine and I have a few screen shots of the Power Connect App. Really cool.
http://www.airforums.com/forums/f240...ml#post1949787
Mcrider is offline   Reply With Quote
Old 05-21-2017, 10:24 AM   #64
FlyFishinRVr's Avatar
2017 Interstate Lounge Ext
Northern , California
Except you have top pull new phone cable through the coach from the controller in the back up to the monitor panel. That's the one reason why I went with the Renogy so I could just re-use the existing Cat5 ethernet cable that AS pulled for the Atkinson.
FlyFishinRVr is offline   Reply With Quote
Old 05-21-2017, 11:49 AM   #65
Njg
Njg's Avatar
Columbia , Missouri
I am using that exact equipment minus the BMV702. Didn't see a need for the monitor with the capabilities of the Bluetooth dongle and smartphone interface. Am I missing anything?
Old 05-21-2017, 04:12 PM   #66
The BMV702 is a nice piece of kit because it comes with a shunt that will allow you to monitor your current draw out of the batteries. With the gear you currently have (and most of the rest of us too, except for those who have totally redone their power systems), you are only seeing voltage.
The good news is you already have the other Victron bits, so if you ever decide to add this, it's fully compatible with what you've already got. Victron definitely has their act together when it comes to power control and monitoring.
Old 05-22-2017, 10:52 AM   #67
Fairhope , Alabama
What a great design. I have recently added 300 watts of Solar, new wiring and added a new Victron solar controller to my 2016 Interstate Grand Tour with the help of AM Solar and now looking to increase my battery capacity. You mentioned you designed the new battery trays pictured in your post. Would you be willing to share the drawings/dimensions and pass on the firm that manufactured your trays? I would like to duplicate your success. Thanks!
EA-6B is offline   Reply With Quote
Old 05-22-2017, 10:59 AM   #68
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
EA-6B: Welcome to the Airforums.
Old 05-23-2017, 01:20 AM   #69
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
EA-6B - that's the Navy aircraft I flew for over a decade! Welcome to the forum.
- - Mike
Boxster1971 is online now   Reply With Quote
Old 05-23-2017, 09:49 AM   #70
Fairhope , Alabama
Boxster1971 (Mike),
Same here. 17 years at NUW. VAQs 138, 140, 129, 137 and CMVWP. Lots of cruises and good memories. Thanks for the welcome to the forum. Steve
Old 09-14-2017, 11:11 AM   #71
2015 Interstate Ext. Coach
Thousand Oaks , California
Originally Posted by JayP View Post
I was inspired by Boxster and did the 4 battery 6v series/parallel install. I installed two in the same place as the originals and then two in the same place curb side. The original boxes were not large enough so I designed and had made larger boxes of very similar design as the originals but wide enough to hold 2 batteries each.
I'm looking to make the same battery addition as JP -- 4 AGMs under the coach. Looks like I can order 4 cases through my Airstream dealer or have 2 larger cases built to accommodate 2 x 6 volt AGMs each. JP: Do you have a source for the larger cases?
Ryoungca is offline   Reply With Quote
Old 01-17-2018, 11:37 AM   #72
Spicewood , Arkansas
JayP. Would you pass on the company that made your under chassis battery boxes? You have designed an awesome set up and no sense reinventing the so called wheel.
pearlygurl is offline   Reply With Quote
Old 09-26-2018, 09:04 PM   #73
Libertyville , Illinois
Hi,
Thought I would revive this thread as I'm sure I'm not the only one looking for GT battery tray options.
As far as I can tell, it appears everyone is going through local custom fabricators, which I am willing to do, but interested if there are other (simpler) options
Eric
Schmitte is offline   Reply With Quote
Help Please, mechanical issues w Interstate ghaag Sprinter and B-van Forum 18 11-01-2015 06:54 PM
Long dog, narrow Interstate - anyone else have issues? InterBlog Sprinter and B-van Forum 34 01-02-2015 04:27 PM
New to us '05 Interstate issues reddog Sprinter and B-van Forum 25 08-13-2013 01:14 PM
Battery Issues imuir Batteries, Univolts, Converters & Inverters 29 08-08-2011 07:27 PM
Battery/charger issues campercan Batteries, Univolts, Converters & Inverters 4 11-09-2008 09:45 AM
