Interstate 24x Broken Driveshaft x2
Anyone had problems with the driveshaft on Interstate 24x?
At 7,500 miles, my drive shaft was replaced because it was bent. Mercedes said it was an Airstream issue because Airstream added the VB rear air suspension.
It happened again, at 16,500 miles, much worse, a piece of the driveshaft broke and fell off, on the interstate, damaging the underside of the vehicle, blowing out a tire, rupturing the aftermarket fuel tank and damaging the heatshield for the exhaust. I have no idea how Airstream can fix the underside of the vehicle and will deal with my ruptured aftermarket fuel tank.
I think the VB air air suspension changing the angle of the driveshaft could be the issue.
Attached is a photo.
