11-07-2017, 08:25 AM
2009 22' Interstate
LaGrange
, Kentucky
Interior Parts?
I have a 2009 Interstate.....that caught on fire....Battery box recall issue.
I'm looking to get some interior parts replaced. Its at an RV dealership and they are stumped....so its up to me to do their job. That's where I find you guys. Need to replace the the rear sleeper area, where can I find the parts? My google skills are normally pretty good but I am having some trouble!
Thank You!
11-07-2017, 09:45 AM
2016 28' International
2015 28' International
2013 28' International
Las Vegas
, Nevada
All of the parts are available from Airstream, if the shop you have it at now is "stumped", you need to get it out of there and take it to a 5 Rivet Airstream dealer. Of course it will be an expensive repair, but nothing beats a good authorized dealer.
Good luck!
11-07-2017, 12:18 PM
2024 Interstate 19
Fulton
, Maryland
Thank You!
Have you got a copy of the 2009 Interstate Part book from Airstream?
That will be a good place to start identifying the parts you need. Most of the parts will only be available from Airstream. Not sure of availability on parts from an eight years old unit.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
11-14-2017, 07:12 AM
2009 22' Interstate
St. Paul
Thank You!
Can you tell me more about the battery box recall issue? I have a 2009 also that I have owned for only eight months. Is there something I need to look at on this?
11-14-2017, 08:20 AM
Sneedville
, Tennessee
https://static.nhtsa.gov/odi/rcl/201...2V596-8558.pdf
11-16-2017, 01:19 PM
2024 Interstate 19
Fulton
, Maryland
Originally Posted by Tincampers
My 2013 Interstate was delivered in October 2012 with this fix installed. It is a real hazard and if a seat belt buckle falls into that space below the lounge seat there will be sparks and possibly a fire. The fix places a thin plywood cover over the open compartment under the lounge seat. It has a 6"x6" opening on left side to provide some ventilation for the inverter/charger in the compartment. I added a piece of plastic screening to the vent opening to make sure nothing falls into that compartment.
- - Mike
11-16-2017, 02:01 PM
Contributing Member
Austin (Hays County)
My 2014.5 had screening already over the 6x6" opening. Apparently, Airstream was learning!
The majority of the heat in that compartment is the solenoid that Airstream added to reduce parasite load when the battery master is turned off. That no longer exists in my AI.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
11-16-2017, 04:43 PM
2013 Interstate Coach
Townsend
, Tennessee
My 2013 Interstate Ext Lounge had the screen over the area with the inverter et al. When Lewster did my upgrade work, the entire area under the couch was seriously “cleaned up”, with covers and wire looms. I have no exposed terminals either......so now I have no real need for the screen and it is gone.
FMCA # 436814
11-17-2017, 12:08 PM
Bellevue
I am not hopeful that Airstream has old parts available. In my new 2016, I found one trim piece that was defective. It was a narrow, 6 foot by 3 inch piece with pocket screws. Dealer ordered it and took weeks to get here. I look and what they sent lacked the pocket screws and the dealer had just screwed it down to compensate.
If they can't reproduce a piece for a current AI, I don't think they can replicate any of the old pieces.
