Old 04-02-2024, 01:44 PM   #1
2015 23' Flying Cloud
2023 Interstate 19
Scottsdale , Arizona
Installing AS Connected in a 2023 Interstate 19 Questions
Getting ready to install a AS connected modem in our 2023 I19.
1.Need to know where the pre-wired power comes from and what amp fuse it has?
2. Will be using Verizon which is what we use for phones. Any recommendations on adding a data plan on top of our existing plan?
cactusjk is offline   Reply With Quote
Old 04-03-2024, 12:18 AM   #2
3OnOurWay's Avatar
2021 Interstate 24GL
For us AS Connected was not worth the money and the limitations.
There are other options using the majority for already installed components,..
2021 AI 24GL 4wd, “maRVel”
3OnOurWay is offline   Reply With Quote
Old 04-03-2024, 07:25 AM   #3
2022 20' Caravel
2019 Interstate Lounge Ext
Noblesville , Indiana
First, though you may see a power connector in the router box behind the drivers seat, odds are it is not connected at the fuse box. However, this wire is present under the ottoman behind the 12' fuse box. So check it out. I'd suggest getting your own peplink router and avoiding the airstream system. For data, if you just periodically need internet, consider the $10 per month / 30GB plan by Tmobile. Im using the MAX BR1 pro.
vanderwielen is offline   Reply With Quote
Old 04-03-2024, 08:37 AM   #4
2023 Interstate 19
Is it easiest to connect power to the fuse panel under the driver’s seat?
Old 04-03-2024, 10:47 AM   #5
3OnOurWay's Avatar
I agree and T-Mobile’s actually running a special right now you will get 2-30 GB cards for the price of one and you can find a standalone pin router for four to $500 to be on 5G.
Easiest to find the fuse that Supplies power to the airstream connected wiring your owners, manual high wiring diagram. There are 12 V options and 120 V options. On our interstate it’s actually wired through the key switch in the aisle way same style of key switch thats used for the battery heaters.
Old 04-03-2024, 05:49 PM   #6
2022 Interstate 19
Cincinnati , Ohio
I have a ‘22, so not sure if they moved them under the ottoman for ‘23, but the (2) white wires that were connected to the barrel power connector were located behind the electrical cabinet panel, along with the other end of the yellow Cat5 cable. The “24 hr power” wire is also labeled and in the cabinet. I added a push button power switch to the panel so I can turn the router off if needed. Also, the new Peplink did not have the round barrel 12v connector, so I bought a pigtail w/ the correct connector, and wired it in after cutting off the crimp connectors under the wood tray behind the driver seat. The two rt pins looking at the back of the router are for +12v, upper left is -, lower left is unused. Some photos attached (I think).
Johnnie S is offline   Reply With Quote
Old 04-04-2024, 02:49 AM   #7
2022 Interstate 19
Cincinnati , Ohio
3On - got your PM, but I’m a newbie and not allowed to reply back w/ a PM. Happy to help! I’d spent about 3 hours searching here and elsewhere for the answer to where the wires originated, so hopefully the pics and info will save others some time. Problem is that they tend to move things each model year.
Also adding - I did the set up of the Peplink in my shop, using the supplied 110v adapter and antennas. Glad I did, because my SIM was not activated by Verizon when I received it, so I had to give them a call to get things rolling. Took about 1/2 hr from unboxing to going live.
Seems like it has a good range of about 30’ away from the vehicle. We used it on a trip to Hocking Hills, and we had good reception. We were able to stream via Roku, and use our tablets, despite the heavy tree cover and mountains.
Old 04-04-2024, 09:17 AM   #8
2023 Interstate 19
The 2023 is different. Sounds like the dealer’s were told to find power on their own.
It also sounds like it should be on a circuit that is live only when the vehicle is on. Not sure why that is and wonder if on shore power will it be on?
Old 04-07-2024, 09:39 AM   #9
2021 30RB Classic
West Sacramento , California
Hi
Have a 2021 Classic. Strongly recommend you do not install AS Connected. Because:
1. The system does not work well at all
2. The modem they install is seriously underpowered for the task
3. You will not get wifi with it
4. it is a serious data hog
5. It is very overpriced
I tore my system out. Replaced it with a better modem. Czone can be reconfigured to give you virtually all the functionality. You will get wifi. If you are installing from scratch, go 5G. You can get a system from any Peplink distributor. I used Mobile Must Have.
Good luck
pboomerx is offline   Reply With Quote
Old 04-07-2024, 10:19 AM   #10
3OnOurWay's Avatar
X2
Also thanks to Mobile Must Have for all the info, how to and help they have on their site to navigate pep wave products.
Old 04-07-2024, 07:38 PM   #11
2023 25' Flying Cloud
Bellevue , WA
Same for me. Please read this article from mobilemusthave.
https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Furldefense.com%2Fv3%2F__https%3 A%2Fsupport.mobilemusthave.com%2Fen%2Fsupport%2Fso lutions%2Farticles%2F67000723407-upgrading-mobile-internet-equipment-in-an-airstream__%3B!!M0aTtQ!f4xc4QzYAv9sQNGiD-iGnz3t_Fe7CmNmmR_aplpt1P-1k0opwuJnLxceghkkVor7YhCQZLXGNbwncQ%2524&data=05%7 C02%7C%7C20cff9bc6112414b181e08dc527423f6%7C84df9e 7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6384759062869 93996%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAi LCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0 %7C%7C%7C&sdata=O8%2Fwd6X%2F2jqt7cdmDqejjzd%2BK3LA VoObfRKeSk4qhWA%3D&reserved=0
I am super disappointed in not being able to upgrade my A/S connect without running new wires.
Lvanden is offline   Reply With Quote
Old 04-08-2024, 03:49 PM   #12
3OnOurWay's Avatar
x2
in my excitement to get up and running did it live in van. It took twice as long plus laptop to get into admin side to smooth over the installing.
Old 04-22-2024, 01:55 PM   #13
2023 Interstate 19
How do you add pictures to private messages?
Old 04-22-2024, 10:47 PM   #14
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
There is no option to attach anything to Private Messages.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 04-23-2024, 12:27 PM   #15
2023 Interstate 19
AT&T plan for 2023 airstream connected hotspot Otto Slater Electronics & Connectivity 21 01-02-2024 04:18 PM
2022 30 ft bunk Airstream Connected prewire connected location mrhankuk Computers, Internet & Satellite 19 07-10-2023 03:35 PM
2023 Interstate 19 Airstream Connect Questions cactusjk Sprinter and B-van Forum 6 05-04-2023 10:45 AM
Ordered a 2023 FC 25FB- wont arrive until spring 2023 waninae39 2016 - Current Flying Cloud 48 07-17-2022 05:39 AM
Airstream Connected... two specific questions HappyHapgood Computers, Internet & Satellite 30 09-26-2021 08:12 AM
