Old 07-28-2019, 07:32 PM   #1
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Identifying components
2018 GT
I was running wires under the galley counter and found a small black box with 8 white wires connecting it tucked into the insulation in the wall. Nothing printed on the box. I haven't identified it from the schematics. Anyone know what it may be?
Also, there are two small PC boards behind the wood panel for the display behind the driver's head. Lots of connecting wires. I haven't tried to trace them yet. Anyone know what they are?
I hate mysteries.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 07-28-2019, 07:35 PM   #2
2013 Interstate Coach
Raymond , Iowa
Just guessing.. Maybe the black box is the relays for the black and gray tank valves? Mine has separate relays but your may have them combined.
Titus is offline   Reply With Quote
Old 07-28-2019, 09:32 PM   #3
Contributing Member
Pahaska's Avatar
Just found a "junction box" listed in the parts list. Since all of the wires going into that box are white, I'm guessing what I found is a junction box bringing together all the grounds on that side of the coach. Grounds are not shown in the schematics.
Still wondering about the two little PC boards behind the touch screen.
John W. Irwin
WBCCI #9632
Old 07-28-2019, 11:02 PM   #4
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
JOHN - a few things:
1. Grounds are shown in the schematics.
2. On House Battery side, prior to the DC going to the Circuit Breakers (CB1-6), AS follows convention and uses Black to designate Ground. I think they have to, in order to seamlessly tie-in with the chassis electrical color coding standards. But after DC goes past the Circuit Breakers and beyond into the individual fuses, AS uses WHITE to designate Ground (shown as AS Ckt# 150 in schemas). Black or Black+anycolor is Hot for a specific circuit. Given your stated location is way past the distribution box, I almost sure the junction you saw is a Ground junction. PS: I do hate how AS does this color switching. Not sure if this is RVIA convention or just random manufacturer choice. Regardless, it confuses the heck out of me.
3. The 2 little pc boards? Only guessing here - Maybe next gen SeeLevel receivers from the sending units to replace the big clunky 1-piece module with LED display that they would hide right inside the wall behind the FireFly touchscreen. Coz they really don't need/use the huge LED display, just the receiver circuitries
Alex AVI is offline   Reply With Quote
Old 07-29-2019, 04:18 AM   #5
Gainesville , Florida
New tech,,,so much simpler!
Need technical info for ordering electric brake components turfclubroad 1980 Caravelle 5 07-06-2009 09:30 PM
Shark-bite Pex components. boatdoc Fresh Water Systems 19 11-05-2008 07:00 AM
Can you ID these exterior "components" on my new '73 Overlander funkill 1970 - 1973 Overlander 25 09-05-2008 10:11 AM
Steering components shocker bkahler Mechanics Corner - Engines, Transmission & More... 2 06-14-2007 04:54 AM
Parts source for 345 rear suspension components? Honkity Hank Classic Motorhomes 3 07-17-2006 12:56 PM
