The Magnum requires 12 volts to operate. Voltage on the Magnum
12 volt connectors must be brought up to the "restart" voltage to restart the Magnum.
See instructions for the Magnum. Note: The Magnum model number is on the inverter/charger unit it self. The remote shown has its own model number.
Start the RV engine. Run it for a while. Leave the RV engine running and try to restart the Magnum. Look on the unit itself. The remote connecting wire may be disconnected. Hopefully the alternator will bring the voltage up and the Magnum will restart.
Lithium batteries will usually restart the same way.
If the alternator will not charge the house batteries, you can use jumper cables to any
12 volt automotive battery or a portable battery charger to get the voltage up.
The Magnum probably has circuit breakers on the unit itself and a high capacity circuit breaker or fuse in the inverter
12 volt cables. There is also a 120 volt circuit breaker feeding the Magnum from the main RV house circuit breaker panel.
Paul Bristol - In the wind!
2025 AirStream Trade Wind
2024 Ford Expedition Max LS with factory towing package
