Originally Posted by gmillerok1
On the 2011 non-extended van, the access hole is just behind the curb side rear corner of the AC unit, which puts it just above and a bit to the center of the back of the area where the gauges are located. Unfortunately, they placed it where it is a couple of inches above and behind the aluminum ceiling which makes it a bit more of a challenge to access. In my unit, the area above the wardrobe is where the AC is located.
The access hole is accessible with a bit of difficulty after removing the instrument control face off where the other gauges are; from there, it goes to the wardrobe, then down to the seat, the back to the controller. I will remove the existing box I put in and replace it with the combiner box.
At least, I'm hoping I can snake 6-2 down and around there!
Sounds right. There was just enough room between the AC and the awning to put my AM Solar combiner box. I used two nylon washers on the awning side to level the combiner box up. I ran cables under the combiner box (as needed) to enter on the appropriate side of the bus.
