Old 07-10-2024, 10:47 AM   #21
Mansderm161's Avatar
Wilmington OHIO , Ohio
I would also check to make sure bird didn't nest under the air conditioner cover blocking the fan. The cover is held on by 4 screws. If a stick wedged in the fan, it could blow the fuse every time you try to reset the fuse and start again. Same thing happens if macerater is stuck. I have the 2018 Interstate.
Mansderm161 is offline   Reply With Quote
Hot hot hot rambler1970 1956 - 1965 Caravel 4 10-04-2023 05:16 PM
Cold, Hot, Cold, Hot, Cold Hot thiel Water Heaters, Filters & Pumps 5 07-15-2023 12:12 AM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
Its Getting Hot in Here! Uberlanders Off Topic Forum 4 05-17-2006 06:32 AM
