Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 06-01-2017, 10:55 AM   #1
Headlight upgrade options for T1N Interstates
I'm starting a new thread because I can't find a single existing thread devoted exclusively to the headlight issue.
Back in 2015, round about page 44, buried deeply in the Interstate Mods thread, we began to discuss this, because LB_3 had begun the process of converting our T1N Sprinter's crappy obsolete halogen OEM headlights over to projectors. But that project proved to be so technically challenging and so time consuming that we bumped other projects up our priority list. The bits and pieces of the intended headlight conversion are still scattered around our garage, unfinished.
Fast forward the better part of two years and I'm wondering if emerging products might begin to address some of this insufficient illumination problem at far lower cost and effort. Those of you who follow RVGeeks probably saw their recent LED headlight retrofit. But of course they have a Class A, so that's potentially a different equation.
The vendor that RVGeeks uses, M4 Products, has been extremely responsive to me on my porch light issue (a badly-conceived LED that we bought back when we were newbies melted off its outer cover and now I have to replace both the fixture and the LED). I've asked them whether they know of anyone who has attempted a T1N Sprinter headlight retrofit using their substitution product, and if so, how was their level of satisfaction? Response pending.
I also chimed in on this recently refreshed Sprinter Forum thread where headlight options are currently in discussion. Responses pending (hopefully).
In the mean time, has anyone on THIS forum experimented with T1N headlight interventions?
I'll leave you with one of our early projector upgrade comparison photos, reproduced from Interstate Mods, so you can see the difference between the original halogen and the projector bulb that we were hoping to adapt, if only it wasn't so danged difficult.
Old 06-30-2019, 10:14 AM   #2
Well, shoot, this old thread didn't go far, but let me resurrect it.
Having run into a dead end on our original projector headlight retrofit goals, I recently took a recommendation from Million Mile Sprinter on an LED retrofit. We replaced both of our halogens in January and while it was not a miracle cure for the T1N's wimpy OEM, it was a definite improvement.
Amazon's description: H7 LED Headlight Bulbs 16000LM 160W 6000K Cool White Low Beam/High Beam Conversion Kit 4-Side COB Chips 360 Degree Super Bright Auto Headlamps -2 Yr Warranty
Fast forward less than 5 months and yet another headlight has gone out. Why? No idea, but here is what the video looks like. The fan still works, the light still is generated... but now it's not much more powerful than a candle.
Weird. Anyway, the quest continues for a *RELIABLE* upfit option.
Old 07-02-2019, 06:39 AM   #3
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
What is the condition of your headlight housing? If hazed, use some plastic polisher (I have used Meguiar's PlastX with good results) and then install a headlight film for long-term protection (I went with Xpel but several brands available).
I have swapped to LED in most of my vehicles. Both headlight bulbs (High and Low beams) as well as the fog lights. It is a good upgrade.
A few photos of one of my cars when I reconditioned the headlights... I installed the headlight film the second time I reconditioned them as without it, they got hazed again... after the film was installed I had no issues from that point on...
In my case, because of how pitted they were, I had to take more drastic measures and sand the headlight housing first before using the PlastX...
ID:	345154   Click image for larger version
ID:	345156   Click image for larger version
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 07-02-2019, 07:05 AM   #4
We did a similar surface restoration process - it's on another thread somewhere. We also used the same kit on my husband's daily driver, which now looks worse than it ever did. Using soft polycarbonate to form headlights was some butt-brained automotive engineer's idea of progress. Not a single one of them on any model of car or truck is worth a pinch of salt.
The primary issue with our older Sprinter is that it wasn't designed to include projectors - it sports an "old fashioned" headlight design that originally accepted halogen bulbs. And projector retrofits are neither available commercially, nor do we have any evidence that anyone has successfully DIY'd them in a T1N Sprinter. (My husband bought the materials to attempt such a conversion, but that project never got off the ground.)
Hence we are attempting to find a reliable LED solution, to brute-force more light out of an obsolete design that was originally poor at throwing it.
Old 07-02-2019, 07:09 AM   #5
wachuko's Avatar
Orlando , Florida
That is why you have to cover the headlight with a film or it will be in the same condition after a few months... ask me how I know... that headlight in the photos I shared was after the first recondition was done... once covered with Xpel, it stayed looking like new.
On the bulbs, I recently got these for my truck
NINEO 9005 HB3 LED Headlight Bulbs - CREE Chips - 12000Lm 6500K Extremely Bright
Not enough time (just a couple of months with them) to provide feedback, but so far, so good... got them from Amazon...
Safe travels!
Wachuko
WBCCI #26769
Old 07-02-2019, 09:13 AM   #6
2007 25' Safari
Rogers , AR
Theres a lot of reasons why LED or HID replacements are not "good," "better," or "safe."
Here is one:
LED bulbs, no matter what they look like, put out a different distribution of light than filament bulbs. That means unlike a filament bulb, physical fit of an LED bulb in a lamp does not necessarily mean it will work safely. Safety here means a lot more than just lighting up in the right color, so it's important to evaluate the performance in the specific lamps on your car.
I've been spending quite a bit of time on the candle power forums and have been educated quite a bit in the transportation/automotive forum there.
If your truck takes a 9005 (65w 1700 lumen) bulb the best/safest option available is the HIR1 (aka 9011, 65w 2300 lumen) bulb which requires a minor trim of the base to fit in place of a 9005 as outline here: https://store.candlepower.com/mohirbuba.html
The best version is manufactured by Toyota (Genuine Toyota 90981-13066 Bulb on amazon)
There are also quality 9011 bulbs manufactured by Philips at a lesser cost.
For you Sprinter owners with H7 (55w 14500 lumen) bulbs. Daniel Stern has convinced Osram to resume manufacturing the H7 "rallye" (65w 2100 lumen) bulb which is essentially an H9 burner on an H7 base.
https://www.danielsternlighting.com/.../products.html
H7 bulbs
These single-filament bulbs are found in the low beams, high beams and fog lamps of many European and Japanese vehicles made since the 1990s. Fun Fact: The H7, introduced in 1993, was the first new halogen headlamp bulb design type-approved to Europe's Regulation 37 in twenty years. It touched off a wave of research and development that saw a dozen new halogen bulb types introduced over the next 15 years.
65W Osram Ultra High Output (2100 lumen, H9 burner on H7 base, race and special-purpose use):
Osram discontinued this bulb several years ago , and all stocks have been exhausted—there are some poor-quality counterfeits flushing around, but those don't count. Update, 27 June 2019: After a great deal of work, I have secured new availability of first-quality, German-made 65w - 2100 lumen H7 bulbs. A paperwork crossup means they didn't get put on the pallet that just arrived. Next pallet's heading out from Germany by air freight in nine days, and they should be on that, so I expect them to be on shelf soon. Send me an email and I'll add you to the waiting list, then ping you as soon as they're in hand to ship.
Mr. Merk is offline   Reply With Quote
Old 07-02-2019, 09:18 AM   #7
2007 25' Safari
Rogers , AR
We did the same thing to our 2008 Cayenne. They were nasty when we bought it. I had our detailer polish them and then coat them in clear film. I've been told that if your lenses are degraded then the reflectors likely have as well but I'm not about to drop $3500 on new headlights for this thing. I'm eager to put the H7 Rallye bulbs in the high beams though!
Old 07-02-2019, 09:41 AM   #8
Originally Posted by Mr. Merk View Post
For you Sprinter owners with H7 (55w 14500 lumen) bulbs. Daniel Stern has convinced Osram to resume manufacturing the H7 "rallye" (65w 2100 lumen) bulb which is essentially an H9 burner on an H7 base. ....
WOW, this is good new information - thank you very much for this post.
Deleting long story, I talked with Daniel maybe 2-ish years ago about this. That was a dead-end inquiry for me, however, because he had nothing innovative to offer at that time.
Right now his website says they are not yet in stock, but I will be following up with him to reassess.
Old 07-02-2019, 10:42 AM   #9
wachuko's Avatar
Orlando , Florida
Mr. Merk - thank you. Great information. Email sent to Daniel to get on the waiting list.
Safe travels!
Wachuko
WBCCI #26769
Old 07-03-2019, 04:42 AM   #10
A bit more detail from Daniel on those H7s that should be delivered from Germany in 3 to 4 more weeks:
"...a 65-watt item producing 2100 lumens (versus the standard 55w H7 bulb's 1410 lumens..."
They will be about $29 each. I am on the waiting list.
Old 07-03-2019, 06:13 AM   #11
2007 25' Safari
Rogers , AR
I hope that these don't create a bulb warning message on the dash in the Sprinters (or my wife's Cayenne.)
At one point I installed a better and much brighter reverse lamp bulb in her Cayenne. The car freaked out and shut down the circuit due to the (safely) increased wattage. I was finally able to install a slightly brighter bulb from Honda without any errors.
Old 07-03-2019, 06:47 AM   #12
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I recently had to replace my headlight bulbs. The new bulbs were Sylvania Ultras, which are brighter halogen filament bulbs. They were a vast improvement over the OEM bulbs. Available at most O'Reilly's Auto Parts stores, but (surprisingly) not at Pep Boys. Since then, I have also put Sylvania Ultras in my Honda as well.
Old 07-03-2019, 07:29 AM   #13
I hope that these don't create a bulb warning message on the dash in the Sprinters ...
My bet would be that Daniel Stern is too meticulous to sell a product that would precipitate an issue like that. We all have our callings in this life. Daniel's calling seems to be headlights, of all things.
Old 07-03-2019, 07:30 AM   #14
wachuko's Avatar
Orlando , Florida
Thumbs up
Same here. Got the same email last night from DS
I tried most of the available options for my motorcycle... I found a bit better performance from the PIAA Extreme White Plus over the Sylvania Ultras. This was before the LED headlight bulbs frenzy...
Safe travels!
Wachuko
WBCCI #26769
Old 07-03-2019, 08:44 AM   #15
2007 25' Safari
Rogers , AR
Both are junk, especially the silverstars. Right now the best options are Philips Xtreme Vision or the GE Nighthawk Platinum
Old 07-03-2019, 09:17 AM   #16
wachuko's Avatar
Orlando , Florida
Like I said, this was before the LED frenzy, so a couple of years ago... I did not know about the GE Nighthawk... I have been pleased with the PIAA... heck, motorcycle still has it (since Jan 2017).
Good to know for when it comes time to replace it.
Safe travels!
Wachuko
WBCCI #26769
Old 07-03-2019, 09:28 AM   #17
2007 25' Safari
Rogers , AR
For reference see this post
https://www.candlepowerforums.com/vb...=1#post2680868
Old 07-03-2019, 10:47 AM   #18
That's a very subjective analysis. On what do you base that "junk" evaluation? Are they too dim? Anything brighter than OEM is an improvement and thus not junk.
Do they not last very long before they need to be replaced? My OEM headlights lasted 7½ years before one burned out, and I haven't had my replacement bulbs long enough to tell how long they'll last. But if one gets at least as much useful life out of replacements as with the OEMs, they're not junk then, either.
Are they street-legal? If they're legal for on-road use they're not junk, but a lot of very bright off-road lights will earn you a citation if used on public roads and thus would be junk in this application.
If they're bright enough, last long enough, and are street legal, then they're not junk even if they're not necessarily the very best.
Old 07-03-2019, 11:34 AM   #19
2007 25' Safari
Rogers , AR
Read the post above (#17.) They are literally the worst. They have the lowest amount of lumens and the lowest life span compared to any other bulbs on the market.
I personally used several sets when I was younger. At one time I sent in a form for a $10 rebate on a set. That was probably between 2005-2010. Ever since then, I get a check in the mail every year or two for a few bucks. Apparently there was a class-action lawsuit against Sylvania for false advertisement or something. I wasn't involved but I guess because of the rebate I was registered as a purchaser.
edit: here is some info on the lawsuit https://topclassactions.com/lawsuit-...checks-mailed/
Old 07-20-2019, 06:24 AM   #20
I took our rig for inspection and registration yesterday, and I was watching it like a hawk because I don't trust the grease monkeys to not bash the solar panels into roll-up doors and other overhead equipment as they wheel it closer to their work bays.
As I'm waiting for them to do the brake test, I glance out and see this (below).
My response, obviously, was an unsanitized version of, "YOU HAVE GOT TO BE FREAKIN' KIDDING ME! SOMEBODY SHOOT ME!"
There was no more than 12 hours of operation on that headlight. We installed it June 30 and it was dead some time before July 19. But I barely drove during that period of deep south roasting.
I don't know whether this is due to bulb defects, or if the Sprinter's electrical system is causing the problem. I've got an email into Joel, and I will investigate this via Sprinter Forum as well.
Now I have to buy an interim set of bulbs, because I've run out of spares, and Daniel Stern's shipment is not coming in for another few weeks.
ADVISORY - Propane hoses on T1N Interstates InterBlog Sprinter and B-van Forum 19 05-31-2017 06:04 AM
Dump hose carrier question (T1N Interstates) InterBlog Sprinter and B-van Forum 24 07-23-2016 04:28 PM
flood damaged interstates 289cobra Sprinter and B-van Forum 16 01-18-2013 05:58 PM
Do Interstates have leak problems like the TTs do? NilesLinus Sprinter and B-van Forum 26 12-09-2012 04:03 AM
Interstates VS secondary roads .... AnnieD On The Road... 14 12-08-2009 02:49 PM
