RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-29-2020, 12:49 PM   #1
Charleston , South Carolina
Gray Water Backup to Shower Pan
We are having the Gray water backup to the shower pan. It happens when we are driving. Anyone else have this issue? Thanks
Charleston40 is offline   Reply With Quote
Old 10-29-2020, 01:15 PM   #2
2016 30' Classic
Rockbridge Baths , Virginia
What is the grey tank level when you travel? Sounds like it is full.
SC RVer is offline   Reply With Quote
Old 10-29-2020, 01:29 PM   #3
It was about half way full.
Old 10-29-2020, 01:47 PM   #4
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
According to the monitoring system? It's not calibrated/accurate then. If gray water is backing up to the shower then the the tank is full. There can be no other reason. The trap under the drain would keep sloshing water to come up in to the shower. Unless the road was so steep that the level of the water in the tilted tank at the moment was *above* the level of the shower floor. Which is very unlikely.
pcskier is offline   Reply With Quote
Old 10-29-2020, 01:47 PM   #5
Is there a way to calibrate the gauges?
Old 10-29-2020, 02:18 PM   #6
Recommended reading on this topic:
(1) The epic thread titled The Flood from several years ago.
(2) This blog post in which I describe how to install a relief / overflow valve on the gray tank so that excess gray water ends up harmlessly discharging beneath your vehicle, rather than filling your shower pan (and possibly spilling out into your Interstate's interior spaces).
Old 10-29-2020, 05:26 PM   #7
Thank you! Great overview and the picture helps too!
Old 10-30-2020, 10:28 AM   #8
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
Because it is the lowest point we use to have grey come up into the shower when the tank is close to full and we move. The simplest solution is to put a lock down plug in the shower drain. We now do this as a habit when we move no mater if the grey is full or empty. No more issue.
rucos is offline   Reply With Quote
Old 11-01-2020, 06:49 PM   #9
2013 28' Flying Cloud
Penn Yan , New York
Backup
We were informed early to put the plug in the shower when moving. Also make sure the water in the toilet is just around the seal when u travel.
delrossa is offline   Reply With Quote
Old 11-01-2020, 07:53 PM   #10
rd tighe's Avatar
2007 25' International CCD FB
South , Texas
Images: 12
We were told empty black and gray tank's and full water when you travel. It's worked for us many years.
Richard (Dean) Tighe
W.B.C.C.I. 5617
2007 25' FB International CCD Solar
2019 Toyota Tundra
rd tighe is offline   Reply With Quote
Old 11-02-2020, 10:09 AM   #11
Silver Star
rucos's Avatar
1970 23' Safari
if you boondock you will always have travel times with full black and grey until you can get to a dump.
2016 Classic Shower/Gray tank problem & shower access FreshAirStmr Sinks, Showers & Toilets 1 09-28-2017 04:02 PM
which wire is the backup wire- rearexterior backup, stop turn light waninae39 Tow Vehicles 38 07-03-2017 07:09 AM
Dish Water, Shower Water, Gray Water... nvestysly Boondocking 63 10-26-2016 02:21 PM
Shower water and the Gray Water Tank MIKO92 All Argosy Trailers 16 07-22-2014 01:53 AM
gray water backup jennian Sprinter and B-van Forum 3 06-21-2014 04:07 PM
