Old 08-02-2020, 05:31 PM   #1
2015 Interstate Grand Tour
Folsom , California
GFCI- no outlets working
Iíve checked fuses. Restarted breaker system. Did not find an outlet with a reset button. What items do I need to check if the GFCI breaker will not stay on and keeps tripping when only TVís are plugged in.
B-Wanderer is offline   Reply With Quote
Old 08-02-2020, 05:36 PM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
TV's MIGHT be a clue. TV's unplugged no problem? OK plug only one in at a time and retest, try to isolate problem.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 08-02-2020, 05:51 PM   #3
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
GFCI will not reset unless you either have external power plugged in or the generator running.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 08-02-2020, 06:40 PM   #4
Punta Gorda , Florida
And many times the GFCI breaker itself fails. They are cheap to replace.
David
DavidEM is offline   Reply With Quote
Old 08-02-2020, 07:27 PM   #5
Folsom , California
Does not reset when on shore power or generator as well
Old 08-02-2020, 07:46 PM   #6
2007 22' International CCD
Time for a new one...?
Old 08-02-2020, 08:14 PM   #7
2013 Interstate Coach
Raymond , Iowa
I recall reading in a previous post that some types/brands of GFCI outlets do not work with the Airstream electrical system. I don't know why that would be...
Titus is offline   Reply With Quote
Old 08-03-2020, 10:36 AM   #8
2017 Interstate Grand Tour Ext
Marco Island , Florida
GFCI Breaker
We had the same problem. The breaker would pop randomly and have to be reset. Technicians weren't much help until I recommended changing the breaker. Sure enough that is all it took. Haven't had a problem since.
wildwilly. is offline   Reply With Quote
Old 08-03-2020, 10:39 AM   #9
Bozeman , Montana
I've just developed the same problem, ready to change the breaker. If someone has a recommendation on a brand please post, thank you!
ArcherTC is offline   Reply With Quote
Old 08-03-2020, 01:25 PM   #10
2014 Interstate Ext. Coach
Las Cruces , New Mexico
GFCI & Outlets Not Working
This situation happened last year. Replaced both GFCI & Breaker. No repeat of the problem since.
JJKinnerup is offline   Reply With Quote
Old 08-03-2020, 03:22 PM   #11
2017 30' International
Dunkirk , Maryland
We had a similar problem. Breaker would reset but trip after a couple hours even with no load on the circuit. I replaced the breaker and solved the problem. Odd that a 4 year old breaker would fail, but new one works fine
Munnik is offline   Reply With Quote
Old 08-03-2020, 05:50 PM   #12
2017 27' International
Oviedo , Florida
If your Circuit breaker is tripping?
I just had the same problem on my 2018 27 FB Sirenity. My AC would not run, gave error code, Replaced 20 amp breaker. Luckily had my AS serviced and they found wires behind breaker panel had loosed up in wire nut and were arcing, burned insulation on wires. They redid connection with new wire nut and wrapped wires with eletrical tape. They said they had seen this before
Where vibration and motion from traveling caused connect to become loose. Check out rear of breaker also for this problem.
David2638 is offline   Reply With Quote
Old 08-03-2020, 06:59 PM   #13
Kensington , Maryland
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 08-04-2020, 02:08 PM   #14
Bozeman , Montana
Thanks!
David 2638 -- great advice.
Too tall -- thank you for the link to the replacement breaker.
David
Old 08-06-2020, 04:34 PM   #15
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I had the same thing and replaced it with an identical GFI from Airstream. It happen while I was at Alumapalooza store ladies got me replacement.
guskmg
Old 08-20-2020, 10:44 AM   #16
Dallas , Texas
Hello! We are needing to replace our GFCI breaker. It’s been acting up for awhile, but now we can’t even reset it. Please give me more info on how to replace it, and where to get the replacement. Thank you!
Claudia5455 is offline   Reply With Quote
Old 08-20-2020, 01:17 PM   #17
Contributing Member
Pahaska's Avatar
Lowe's, HD, or pretty much any electrical supplier. Best to take the old one with you. The replacement may be from a different manufacturer, but it is easy to hold them up together and compare.
John W. Irwin
WBCCI #9632
Old 08-20-2020, 08:15 PM   #18
gator.bigfoot's Avatar
KW , Ontario
Originally Posted by Claudia5455 View Post
Hello! We are needing to replace our GFCI breaker. Itís been acting up for awhile, but now we canít even reset it. Please give me more info on how to replace it, and where to get the replacement. Thank you!
Which breaker are you referring too? Most of the trailers use GFCI outlets not breakers, as this is a much cheaper option. Now if your trailer uses a breaker then you should first try disconnecting any wires from the load side of the breaker first and then see if it resets. If it does then most likely there is nothing wrong with the breaker. However if the breaker does not reset then you do have an issue with that breaker. As mentioned you can pick one from any electrical supplier or hardware store.
gator.bigfoot is offline   Reply With Quote
Old 08-20-2020, 08:28 PM   #19
Contributing Member
Pahaska's Avatar
The OC has a 2018 Interstate, not a trailer. Recent interstates use one GFCI breaker to serve the galley and outside outlets. Older Interstates (my 2014.5 for instance) did have an outlet breaker just aft of the driver's seat.
John W. Irwin
WBCCI #9632
All outlets not working NicheVintage Lights - Interior & Exterior 12 11-19-2020 04:01 PM
Problem with GFCI outlets mikeinca Batteries, Univolts, Converters & Inverters 7 07-03-2019 08:02 PM
Front vs back GFCI outlets BurntAsphalt Sprinter and B-van Forum 4 06-25-2016 11:19 PM
New outlets / GFCI protection question bredlo Electrical - Systems, Generators, Batteries & Solar 9 12-18-2015 11:10 AM
Outlets not working - 74 tradewind pamelake Electrical - Systems, Generators, Batteries & Solar 14 03-31-2009 05:20 PM
