Old 07-17-2020, 12:25 PM   #1
Traverse City , Michigan
Generator positive wire
I am in the middle of upgrading to lithium batteries on my 2016 GT Ext and bringing them in the coach.
How have others wired the generator positive wire? Did you use an enclosed buss bar under the vehicle and run a wire up into the coach to hook to the batteries? Or run a new wire the right length from the generator to the batteries?
Heckler56 is offline   Reply With Quote
Old 07-17-2020, 01:05 PM   #2
2015 Interstate Grand Tour
Libertyville , Illinois
I ran a new wire up into the coach
Schmitte is offline   Reply With Quote
Old 07-17-2020, 02:11 PM   #3
All the way from inside the generator?
Old 07-17-2020, 07:11 PM   #4
Yes, I ran the positive wire for starting the generator back into the coach to a post thermal near the inverter. I use my van year round and didn’t want any connections under the van to corrode from winter salt
Old 07-18-2020, 11:48 AM   #5
2013 Interstate Coach
Waterloo , Iowa
The only under-the-van connections for my generator are on the lower, front, curb-side corner. I took the wires off a couple of years ago to clean them. Very dirty and corroded with pebbles stuck between the wiring and the frame. There was so much debris that I'm surprised the positive post didn't short to ground - especially when the gunk was wet. Like Schmitte I wouldn't want to have another connection exposed to that environment. Not sure why you would consider rewiring the generator when switching to lithium.
Titus is offline   Reply With Quote
Old 07-18-2020, 04:29 PM   #6
[QUOTE=Titus;2385341 Not sure why you would consider rewiring the generator when switching to lithium.[/QUOTE]
I have no sham in admitting I am in uncharted territory trying to upgrade the solar and batteries. Not sure if you mean that I would “not use the generator “ going forward now that I am going with a lithium set up? If so, I am only using two lithium batteries. If I want to run the AC I will still need the generator. At this point the generator is the last place I have not been in.
Since I am moving the batteries inside but on the opposite side of the vehicle I was hoping to reuse some wiring and not have to yank out all of the old wiring feeding the original battery bank underneath.
Old 07-18-2020, 05:20 PM   #7
Did you run it to battery bank direct or a buss after your class t fuse block?
Old 07-19-2020, 07:21 AM   #8
Waterloo , Iowa
Sorry for the confusion. I hadn't thought about you changing battery location, which would lead to a re-wire. But I don't see any reason for the re-wire to include a third connection anywhere - especially underneath and exposed to debris.
Old 07-19-2020, 08:21 AM   #9
The third connection was a consideration to get this on the road by next week. Road race in WI I cannot miss. Shopping around there is a problem with part shortages. Went into my local West Marine yesterday and thought they were going out of business. Amazon is also seriously delayed.
Old 07-19-2020, 10:25 AM   #10
I ran it to a buss terminal under the driver side jump seat where all the electrical stuff is. You will need some ‘great stuff’ foam to re-seal the hole in the floor under the cup holder
Old 07-19-2020, 11:49 AM   #11
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
I also moved my lithium batteries inside during my upgrade. After the initial wiring, the generator would not start. No power was getting to gen starter.
I moved all wiring from the old Isolator in favor of a new DC to DC charger between my alternator and new lithium coach batteries. So I disconnected the old coach battery connection (from the top left of the Isolator) thinking I did not need it and not knowing it somehow sent power back to my generator starter.
I connected the old coach battery cable positive (previously on the top left of the Isolator) to a positive wire from the new lithium. The generator now starts and runs like before.
Note: Previously, upon removing my old batteries from the outside battery compartment, I insulated the old cable-lug ends in with shrink-tubbing to eliminate the chance of shorts or grounds.
Here is what my Isolator looks like in case it is still the model used in your '2016.
rowiebowie is offline   Reply With Quote
Dedicated positive wire for solar? JimmyT Generators & Solar Power 8 05-22-2010 10:16 AM
Small Positive Battery Lead Sundance Batteries, Univolts, Converters & Inverters 2 07-12-2007 12:19 PM
Any ST trailer tire that gets positive reviews? 63air Tires 13 08-06-2006 02:39 PM
WBCCI Families & Youth - Positive Reinforcement LuminumTraila WBCCI Forum 44 07-18-2006 10:51 AM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
