10-02-2020, 11:15 AM
#61
Libertyville
Following! Seems like it could be a big job, though.
10-02-2020, 11:24 AM
#62
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Originally Posted by wachuko
Very cool, thanks. I now see this detail in his second PDF. Yep, looks like quite a bit of work, but it's great to know that this helps the situation. I'd probably hire someone to do this for me, vs. getting under there myself, but one never knows.
10-02-2020, 11:30 AM
#63
Prof. of Pending Projects
2018 Tommy Bahama Interstate
Orlando
I hold the generator in place with a motorcycle jack while I remove the mounts. Easy to do if all the bolts are not rusted out... My guesstimate is that this will takes less than an hour to do...
10-02-2020, 11:38 AM
#64
Green Cove Springs
Oh, handy, an excuse to buy another tool! May have to try it myself.
10-03-2020, 06:05 AM
#65
GREAT ESCAPES
2014 Interstate Ext. Coach
Tenafly
, New Jersey
Generator Noise
I've done a couple of things, and finally think I have my generator noise at an acceptable level; the biggest step was removing the three resting feet from the bottom of the unit (Torx screw).
Summary:
1st - Installed the silencer (-3dB) in exhaust noise
2nd - Installed rubber coated washers as suggested in an earlier thread
3rd - Install rubber floor matting,which is typically used in horse trailers between the generator and mounting bracket (big improvement)
4th - Adjusted the exhaust manifold so as to not make contact with the generator housing and exhaust pipe.
5th - Final and best improvement from a vibration noise standpoint; I removed the three resting feet from the bottom of the generator. Again, the vibration from the resting feet and the generator housing seemed to be making contact, especially if the Interstate was completely level when using the generator.
I hope this helps...
01-23-2021, 09:53 AM
#66
2015 Interstate Ext. Coach
Lake Mary
It looks so clean underneath that you must have no mileage )))
01-23-2021, 05:02 PM
#67
2016 23' International
Los Angeles
I would strongly recommend that you not remove the ‘3 resting feet” from the genset. These are actually failsafe features that prevent the motor and alternator from separating from the base pan if the internal mounting isolators fail.
If you have noise coming from one of the 3 feet, it means that a rubber isolator is failing and deforming inside of the unit and needs to be replaced.
Removing these feet, especially when they are making contact with the base pan can lead to the motor coming loose inside of the enclosure and starting a fire, causing electrical shock, or severe damage to the unit and ultimately your coach.
02-04-2021, 08:25 AM
#68
2020 Interstate 19
Pensacola
Noico pads
On the IS 19 FB pages I posted my experience with the Noico noise pads I wrapped my gen in. I cut each in half, and carefully wrapped all the side AND top with multiple layers.
The only caution (in installation manual) is that the access panel be left open AND the bottom (cooling air exits). The install manual encourages using a 1” wrapper style noise system.......difficult on our AS IS’
Has made gen VERY quite, no cooling issuers at all........
‘20 IS 19’ TB, 2wd
Pensacola,FL
02-05-2021, 12:38 AM
#69
Lake Mary
How many Mil noico pad thickness, and how many layers you put to achieve this result?
02-06-2021, 07:54 AM
#70
2020 Interstate 19
Pensacola
Noico 80 mil pads, 10 sq ft
Hi folks...I used the 80 mil pads, bought the 10 sq ft package.....will buy some more...
Major PITA to install, but I cut into smaller pieces.....very sticky stuff.....then I wrapped large pieces with aluminum “100 mph” tape.
If you read the (very) techy installation manual online, Onan reccs a sound insulation procedure...
No probs to date !
‘20 IS 19’ TB, 2wd
Pensacola,FL
02-07-2021, 10:26 AM
#71
Lake Mary
No probs to date !
Wouldn’t 315 mil be an overbuild? The link is below
https://www.amazon.com/gp/product/B0...NOZL83GP&psc=1
02-07-2021, 10:39 AM
#72
2018 Atlas
Milford
, Ontario
Generator Noise
I find the generator on my Atlas to be noisy. As mentioned in another reply, the noise is more like a metallic rattle rather than a loud exhaust.
02-07-2021, 07:14 PM
#73
Carmel
Generator Noise
I have 2017 Airstream, just purchased not too long ago, I was shocked at the loudness of the generator, the noise and vibration would make it impossible to sleep if this thing were running. Outside is same, I went to add a resonator on the exhaust and this too made very little difference. The cleaning of the muffler at the u clamp was a little loose so had that tightened and still loud. Just the way it is I guess, added dynamate to the sides also trying to mitigate some of the noise.
02-08-2021, 03:07 PM
#74
Green Cove Springs
We had a similar experience with sticking a Cummins resonator on the end of our generator's exhaust pipe. The quality of the sound outside changed a little bit and seemed a tad less annoying, but the measured decibels didn't change at all. [emoji45]
02-08-2021, 11:04 PM
#75
Carmel
I am with one of the posts that had the idea of using a jack under it especially on concrete or asphalt seems like minor pressure from underneath would help anchor it so the vibration and rattle would be less
02-09-2021, 03:39 PM
#76
Los Angeles
Onan is offering a new inverter based generator that is about 1/3 as loud and will be a drop in replacement for the existing qg 2500 LP units.
Look up the Onan qg 2500i LP
All mounting points are identical, the base pan is about 10mm lower then the old model and the exhaust outlet is located a few mm down as well.
02-09-2021, 03:44 PM
#77
Los Angeles
We also use the motorcycle lift for our installation and service on these gensets.
There really isn’t a better solution and the price is right!
02-09-2021, 04:59 PM
#78
Libertyville
Has anyone here heard this new Onan? I would consider if I knew it was reasonably quiet.
02-09-2021, 05:22 PM
#79
Los Angeles
We actually produce installation systems for the travel trailers and are going to be receiving our first 2500i this week from Cummins.
I’ll post the db difference once we test the 2 models side by side.
In the meantime, you can see a comparison video here:
02-09-2021, 06:07 PM
#80
2021 Interstate 24GT
Cordova
, Tennessee
I just confirmed that this is the model generator that is installed on our new 2021 24GT, and I can also confirm that it is indeed much quieter than the model on our 2017 Lounge.
